Datasheet ADG1236 (Analog Devices) - 10
Description | Low Capacitance, Low Charge Injection, ±15 V/12 V iCMOS, Dual SPDT Switch |
Pages / Page | 16 / 10 — ADG1236. Data Sheet. 0.35. 220. VDD = 12V V. 0.30. SS = 0V. 200. BIAS = … |
Revision | A |
File Format / Size | PDF / 351 Kb |
ADG1236. Data Sheet. 0.35. 220. VDD = 12V V. 0.30. SS = 0V. 200. BIAS = 1V/10V. 0.25. 180. AOFF BON 12V SS. 160. AOFF BON 15V DS. 0.20. 140. 0.15. 120
ADG1236 Data Sheet 0.35 220 VDD = 12V V 0.30 SS = 0V V 200 BIAS = 1V/10V 0.25 180 AOFF BON 12V SS 160 AOFF BON 15V DS 0.20 140 0.15 I 120 D, IS (ON) 0.10 B 100 OFF AON 12V SS TIME (ns) LEAKAGE (nA) 0.05 80 I 60 0 S (OFF) BOFF AON 15V DS 40 –0.05 20 –0.10
04776-017
0
04776-004
0 20 40 60 80 100 120 –40 –20 0 20 40 60 80 100 120 TEMPERATURE (
C) TEMPERATURE (
C)
Figure 10. Leakage Currents as a Function of Temperature, Single Supply Figure 13. tTRANSITION Times vs. Temperature
60 0 IDD PER CHANNEL VDD = 15V TA = 25
C –10 VSS = –15V 50 TA = 25
C –20 40 VDD = 15V –30 VSS = –15V –40
µ
A) ( 30 –50 I DD –60 20 OFF ISOLATION (dB) –70 V 10 DD = 12V –80 VSS = 0V –90 0
04776-018
0 2 4 6 8 10 12 14 –100
04776-010
10k 100k 1M 10M 100M 1G LOGIC, INX (V) FREQUENCY (Hz)
Figure 11. IDD vs. Logic Level Figure 14. Off Isolation vs. Frequency
6 0 TA = 25
C VDD = 15V –10 VSS = –15V 4 TA = 25
C –20 2 –30 –40 0 VDD = 15V V –50 SS = –15V VDD = 12V BETWEEN VSS = 0V –60 SA AND SB –2 CROSSTALK (dB) CHARGE INJECTIOIN (pC) –70 –4 –80 BETWEEN –90 S1 AND S2 –6
04776-005
–100
04776-008
–15 –10 –5 0 5 10 15 10k 100k 1M 10M 100M 1G VBIAS (V) FREQUENCY (Hz)
Figure 12. Charge Injection vs. Source Voltage Figure 15. Crosstalk vs. Frequency Rev. A | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TRUTH TABLE FOR SWITCHES PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
