Datasheet ADG1236 (Analog Devices) - 9
DescriptionLow Capacitance, Low Charge Injection, ±15 V/12 V iCMOS, Dual SPDT Switch
Pages / Page16 / 9 — Data Sheet. ADG1236. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. DD = …
File Format / SizePDF / 351 Kb
Data Sheet. ADG1236. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. DD = 15V. A = 25. 180. SS = –15V. VSS = –15V. 160. VDD = 13.5V
Data Sheet ADG1236 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 DD = 15V A = 25 180 SS = –15V VSS = –15V 160 VDD = 13.5V
Data Sheet ADG1236 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 V T DD = 15V A = 25
C V V 180 DD = 15V SS = –15V VSS = –15V 160 VDD = 13.5V 200 VSS = –13.5V TA = +125
C ) )
140
TA = +85
C 120 150 TA = +25
C 100 VDD = 16.5V VSS = –16.5V 80 100 TA = –40
C ON RESISTANCE ( ON RESISTANCE ( 60 40 50 20 0
04776-014 04776-011
0 –18 –15 –12 –9 –6 –3 0 3 6 9 12 15 18 –15 –10 –5 0 5 10 15 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (
C)
Figure 4. On Resistance as a Function of VD (VS) for Dual Supply Figure 7. On Resistance as a Function of VD (VS) for Different Temperatures, Dual Supply
600 600 V T DD = 12V A = 25
C VDD = 4.5V V V TA = +125
C SS = 0V SS = –4.5V 500 500 VDD = 5V TA = +85
C ) VSS = –5V )
Ω Ω
400 400 TA = +25
C 300 VDD = 5.5V 300 VSS = –5.5V TA = –40
C 200 200 ON RESISTANCE ( ON RESISTANCE ( 100 100 0
04776-015 04776-012
0 –6 –4 –2 0 2 4 6 0 2 4 6 8 10 12 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (
C)
Figure 5. On Resistance as a Function of VD (VS) for Dual Supply Figure 8. On Resistance as a Function of VD (VS) for Different Temperatures, Single Supply
450 0.20 V T DD = 15V A = 25
C VDD = 10.8V VSS = –15V 400 VSS = 0V 0.15 VBIAS = +10V/–10V 350 VDD = 12V 0.10 IS (OFF) ) VSS = 0V
300 0.05 250 VDD = 13.2V 0 V 200 SS = 0V LEAKAGE (nA) –0.05 ID, IS (ON) 150 ON RESISTANCE ( –0.10 100 –0.15 50 0 –0.20
04776-016 04776-013
0 2 4 6 8 10 12 14 0 20 40 60 80 100 120 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (
C)
Figure 6. On Resistance as a Function of VD (VS) for Single Supply Figure 9. Leakage Currents as a Function of Temperature, Dual Supply Rev. A | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TRUTH TABLE FOR SWITCHES PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
