Datasheet ADG1236 (Analog Devices) - 6
DescriptionLow Capacitance, Low Charge Injection, ±15 V/12 V iCMOS, Dual SPDT Switch
Pages / Page16 / 6 — ADG1236. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. …
File Format / SizePDF / 351 Kb
ADG1236. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. ESD CAUTION. TRUTH TABLE FOR SWITCHES. Table 4. Switch A
ADG1236 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION TRUTH TABLE FOR SWITCHES Table 4 Switch A
Table 3.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a VDD to VSS 35 V stress rating only; functional operation of the product at these VDD to GND −0.3 V to +25 V or any other conditions above those indicated in the operational VSS to GND +0.3 V to −25 V section of this specification is not implied. Operation beyond Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or the maximum operating conditions for extended periods may 30 mA, whichever occurs first affect product reliability. Digital Inputs1 GND − 0.3 V to VDD + 0.3 V or
ESD CAUTION
30 mA, whichever occurs first Peak Current, S or D 100 mA (pulsed at 1 ms, 10% duty cycle max) Continuous Current per 25 mA Channel, S or D Operating Temperature Range Automotive (Y Version) −40°C to +125°C Storage Temperature Range −65°C to +150°C
Junction Temperature 150°C 16-Lead TSSOP, θ
Table 4.
JA Thermal 112°C/W Impedance
IN Switch A Switch B
12-Lead LFCSP, θ 0 Off On JA Thermal 80°C/W Impedance 1 On Off Reflow Soldering Peak 260°C Temperature, Pb Free 1 Over voltages at IN, S, or D are clamped by internal diodes. Current must be limited to the maximum ratings given. Rev. A | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TRUTH TABLE FOR SWITCHES PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
