Datasheet ADG441, ADG442, ADG444 (Analog Devices) - 7
DescriptionLC2MOS Quad SPST Switches
Pages / Page16 / 7 — Data Sheet. ADG441/ADG442/ADG444. TYPICAL PERFORMANCE CHARACTERISTICS. …
File Format / SizePDF / 315 Kb
Data Sheet. ADG441/ADG442/ADG444. TYPICAL PERFORMANCE CHARACTERISTICS. 100. 0.02. A = 25°C. DD = +5V. DD = +15V. VSS = –5V
Data Sheet ADG441/ADG442/ADG444 TYPICAL PERFORMANCE CHARACTERISTICS 100 0.02 A = 25°C DD = +5V DD = +15V VSS = –5V
Data Sheet ADG441/ADG442/ADG444 TYPICAL PERFORMANCE CHARACTERISTICS 100 0.02 T V V A = 25°C DD = +5V DD = +15V VSS = –5V VSS = –15V TA = 25°C ID (OFF) 80 0.01 VDD = +12V V ) SS = –12V
( 60 0 V ID (ON) ON DD = +10V R VSS = –10V IS (OFF) 40 –0.01 LEAKAGE CURRENT (nA) VDD = +15V VSS = –15V 20 –0.02 –15 –10 –5 0 5 10 15 –15 –10 –5 0 5 10 15 VD (VS) (V)
05233-005
VS (VD) (V)
05233-008 Figure 4. RON as a Function of VD (VS): Dual Supply Figure 7. Leakage Currents as a Function of VS (VD)
170 120 VDD = 5V T V A = 25°C DD = +15V VSS = 0V VSS = –15V 150 110 130 100 110 CROSSTALK VDD = 10V VDD = 12V 90 ) VSS = 0V VSS = 0V
( 90 dB ONR 80 70 OFF ISOLATION 70 50 VDD = 15V 30 60 VSS = 0V 10 50 0 3 6 9 12 15 1k 10k 100k 1M 10M VD (VS) (V)
05233-006
FREQUENCY (Hz)
05233-009 Figure 5. RON as a Function of VD (VS): Single Supply Figure 8. Crosstalk and Off Isolation vs. Frequency
100 120 VDD = +15V VDD = 12V VSS = –15V VSS = 0V 100 80 125°C 125°C 80 ) )
Ω Ω
( 60 ( 85°C ON ON R R 25°C 60 85°C 40 40 25°C 20 20 –15 –10 –5 0 5 10 15 0 2 4 6 8 10 12 VD (VS) (V)
05233-007
VD (VS) (V)
05233-010 Figure 6. RON as a Function of VD (VS) for Different Temperatures Figure 9. RON as a Function of VD (VS) for Different Temperatures Rev. B | Page 7 of 16 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications Dual Supply Single Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Outline Dimensions Ordering Guide
