Datasheet 1N4099 (MCC) - 2
Manufacturer | MCC |
Description | 500mW Silicon Zener Diodes |
Pages / Page | 5 / 2 — Micro Commercial Components. ELECTRICAL CHARACTERISTICS. 1. TOLERANCE AND … |
File Format / Size | PDF / 200 Kb |
Micro Commercial Components. ELECTRICAL CHARACTERISTICS. 1. TOLERANCE AND TYPE NUMBER DESIGNATION (VZ). NOTES
1N4614 thru 1N4125 M C C TM
Micro Commercial Components ELECTRICAL CHARACTERISTICS
(TA = 25ºC unless otherwise noted, VF = 1.1 V Max @ IF = 200mA for all types) (3) Zener Voltage (2) Maximum ReverseLeakage Current (4) Zener Impedance (5) Zener(IZM) Device (1) Device V @IZT=250UA Current IR@VR Z @IZT Z (Volts) Marking ZT Min Nom Max mA uA( Max) Volts ohm(Max) 1N4614 1N4614 1.71 1.8 1.89 120 7.5 1 1200 1N4615 1N4615- 1.90 2.0 2.10 110 5.0 1 1250 1N4616 1N4616----- 2.09 2.2 2.31 100 4.0 1 1300 1N4617 1N4617- 2.28 2.4 2.52 95 2.0 1 1400 1N4618 1N4618--- 2.565 2.7 2.835 90 1.0 1 1500 1N4619 1N4619 -- 3.0 3.15 87 0.8 2.85 1 1600 1N4620 1N4620 -- 3.135 3.3 3.465 85 7.5 1.5 1650 1N4621 1N4621- 3.42 3.6 3.78 83 7.5 2 1700 1N4622 1N4622-- 3.705 3.9 4.095 80 5.0 2 1650 1N4623 1N4623-- 4.085 4.3 4.515 77 4.0 2 1600 1N4624 1N4624--- 75 4.465 4.7 4.935 10.0 3 1550 1N4625 1N4625- 4.845 5.1 5.355 70 10.0 3 1500 1N4626 1N4626------ 5.32 5.6 5.88 65 10.0 4 1400 1N4627 1N4627-- 5.89 6.2 6.51 61 10.0 5 1200 1N4099 1N4099 --- 6.46 6.8 7.14 56 10.0 5.17 200 1N4100 1N4100 --- 7.125 7.5 7.875 51 10.0 5.70 200 1N4101 1N4101 7.79 8.2 8.61 46 1.0 6.24 200 1N4102 1N4102 8.265 8.7 9.135 44 1.0 6.61 200 1N4103 1N4103 8.645 9.1 9.555 42 1.0 6.92 200 1N4104 1N4104- 9.5 10 10.5 38 1.0 7.60 200 1N4105 1N4105 10.45 11 11.55 35 .05 8.44 200 1N4106 1N4106 11.4 12 12.6 32 .05 8.12 200 1N4107 1N4107 12.35 13 13.65 29 .05 9.857 200 1N4108 1N4108 13.3 14 14.7 27 .05 10.65 200 1N4109 1N4109 14.25 15 15.75 25 .05 11.40 100 1N4110 1N4110 15.2 16 16.8 24 .05 12.15 100 1N4111 1N4111 16.15 17 17.85 22 .05 12.92 100 1N4112 1N4112 17.1 18 18.9 21 .05 13.67 100 1N4113 1N4113 18.05 19 19.95 20 .05 14.44 150 1N4114 1N4114 19 20 21 19 .01 15.20 150 1N4115 1N4115 20.9 22 23.1 17 .01 16.72 150 1N4116 1N4116 22.8 24 25.2 16 .01 1 18.25 150 1N4117 1N4117 23.75 25 26.25 1 15 .01 19.00 150 1N4118 1N4118 25.65 27 28.35 14 .01 20.45 150 1N4119 1N4119 26.6 28 29.4 1 14 .01 21.28 200 1N4120 1N4120 28.5 30 31.5 13 .01 22.80 200 1N4121 1N4121 31.35 33 34.65 12 .01 25.08 200 1N4122 1N4122 34.2 36 37.8 11 .01 27.38 200 1N4123 1N4123 37.05 39 40.95 9.8 .01 29.65 200 1N4124 1N4124 40.85 43 45.15 8.9 .01 32.65 250 1N4125 1N4125 44.65 47 49.35 8.1 .01 35.75 250
1. TOLERANCE AND TYPE NUMBER DESIGNATION (VZ) NOTES
: The type numbers listed have a standard tolerance on the nominal zener voltage of ±5%.
2. ZENER VOLTAGE (VZ) MEASUREMENT
Nominal zener voltage is measured with the device junction in the thermal equilibrium at . the lead temperature (TL) at 30°C ±1°C and 3/8” lead length.
3. MAXIMUM ZENER CURRENT RATINGS (IZM)
This data was calculated using nominal voltages. The maximum handing current capability on a worst case basis is limited by the actual zener voltage at the opertation piont and the power derating curve. 4.
Reverse Leakage Current(IR)
reverse leakage current are guaranteed and measured at VR shown on the table . 5.
Zener Impedance(ZZT) Derivation
The Zener impedance is derived from the 60 cycle ac voltage.which results when an Ac .current having an rms value to 10% of the DC zener current (IZT) is superimposed on IZT. www.mccsemi.com Revision: B 2012/01/01
2 of 5
