Datasheet 74LVC1G3157 (Nexperia) - 6
Manufacturer | Nexperia |
Description | 10 Ohm Single-Pole Double-Throw Analog Switch |
Pages / Page | 22 / 6 — Nexperia. 74LVC1G3157. 10 Ohm single-pole double-throw analog switch |
File Format / Size | PDF / 337 Kb |
link to page 7 link to page 8 link to page 6 link to page 7 link to page 7 link to page 7 link to page 6
Nexperia 74LVC1G3157 10 Ohm single-pole double-throw analog switch
V switch S CC 1 VIH S Y0 1 2 VIL VIL or VIH switch Z Y1 2 IS VI VO GND 001aac359 VI = VCC or GND and VO = open circuit.
Fig. 4. Test circuit for measuring ON-state leakage current 10.2. ON resistance Table 8. ON resistance
At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Fig. 6 to Fig. 11.
Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max
RON(peak) ON resistance VI = GND to VCC; see Fig. 5 (peak) ISW = 4 mA; VCC = 1.65 V to 1.95 V - 34.0 130 - 195 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 12.0 30 - 45 Ω ISW = 12 mA; VCC = 2.7 V - 10.4 25 - 38 Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 7.8 20 - 30 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 6.2 15 - 23 Ω RON(rail) ON resistance VI = GND; see Fig. 5 (rail) ISW = 4 mA; VCC = 1.65 V to 1.95 V - 8.2 18 - 27 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.1 16 - 24 Ω ISW = 12 mA; VCC = 2.7 V - 6.9 14 - 21 Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 6.5 12 - 18 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 5.8 10 - 15 Ω VI = VCC; see Fig. 5 ISW = 4 mA; VCC = 1.65 V to 1.95 V - 10.4 30 - 45 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.6 20 - 30 Ω ISW = 12 mA; VCC = 2.7 V - 7.0 18 - 27 Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 6.1 15 - 23 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 4.9 10 - 15 Ω RON(flat) ON resistance VI = GND to VCC [2] (flatness) ISW = 4 mA; VCC = 1.65 V to 1.95 V - 26.0 - - - Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 5.0 - - - Ω ISW = 12 mA; VCC = 2.7 V - 3.5 - - - Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 2.0 - - - Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 1.5 - - - Ω [1] Typical values are measured at Tamb = 25 °C and nominal VCC. [2] Flatness is defined as the dif erence between the maximum and minimum value of ON resistance measured at identical VCC and temperature. 74LVC1G3157 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2023. Al rights reserved
Product data sheet Rev. 10 — 13 April 2023 6 / 22
Document Outline 1. General description 2. Features and benefits 3. Ordering information 4. Marking 5. Functional diagram 6. Pinning information 6.1. Pinning 6.2. Pin description 7. Functional description 8. Limiting values 9. Recommended operating conditions 10. Static characteristics 10.1. Test circuits 10.2. ON resistance 10.3. ON resistance test circuit and graphs 11. Dynamic characteristics 11.1. Waveforms and test circuits 11.2. Additional dynamic characteristics 11.3. Test circuits 12. Package outline 13. Abbreviations 14. Revision history 15. Legal information Contents
