Datasheet NTCLE100E3 (Vishay) - 2
Manufacturer | Vishay |
Description | NTC Thermistors, Radial Leaded, Standard Precision |
Pages / Page | 17 / 2 — NTCLE100E3. ELECTRICAL DATA AND ORDERING INFORMATION. SAP MATERIAL AND … |
File Format / Size | PDF / 226 Kb |
NTCLE100E3. ELECTRICAL DATA AND ORDERING INFORMATION. SAP MATERIAL AND ORDERING NUMBER (1). 25-TOL. B25/85. B25/85-TOL. RECOG
NTCLE100E3
www.vishay.com Vishay BCcomponents
ELECTRICAL DATA AND ORDERING INFORMATION UL SAP MATERIAL AND ORDERING NUMBER (1) R 25 R 25-TOL. B25/85 B25/85-TOL. RECOG. NTCLE100E3..B0/T1/T2 (
Ω
) (± %) (K) (± %) NTCLE100E3..B0A/T1A/T2A RoHS-COMPLIANT RoHS-COMPLIANT WITH EXEMPTION (2)
330 5 3560 1.5 ✓ 331*B0 331*B0A 470 5 3560 1.5 ✓ 471*B0 471*B0A 680 5 3560 1.5 ✓ 681*B0 681*B0A 1000 2, 3, 5 3528 0.5 ✓ 102*B0 102*B0A 1500 2, 3, 5 3528 0.5 ✓ 152*B0 152*B0A 2000 2, 3, 5 3528 0.5 ✓ 202*B0 202*B0A 2200 2, 3, 5 3977 0.75 ✓ 222*B0 222*B0A 2700 2, 3, 5 3977 0.75 ✓ 272*B0 272*B0A 3300 2, 3, 5 3977 0.75 ✓ 332*B0 332*B0A 4700 2, 3, 5 3977 0.75 ✓ 472*B0 472*B0A 5000 2, 3, 5 3977 0.75 ✓ 502*B0 502*B0A 6800 2, 3, 5 3977 0.75 ✓ 682*B0 682*B0A 10 000 2, 3, 5 3977 0.75 ✓ 103*B0 103*B0A 12 000 2, 3, 5 3740 2 ✓ 123*B0 123*B0A 15 000 2, 3, 5 3740 2 ✓ 153*B0 153*B0A 22 000 2, 3, 5 3740 2 ✓ 223*B0 223*B0A 33 000 2, 3, 5 4090 1.5 ✓ 333*B0 333*B0A 47 000 2, 3, 5 4090 1.5 ✓ 473*B0 473*B0A 50 000 2, 3, 5 4190 1.5 ✓ 503*B0 503*B0A 68 000 2, 3, 5 4190 1.5 ✓ 683*B0 683*B0A 100 000 2, 3, 5 4190 1.5 ✓ 104*B0 104*B0A 150 000 2, 3, 5 4370 2.5 ✓ 154*B0 154*B0A 220 000 2, 3, 5 4370 2.5 ✓ 224*B0 224*B0A 330 000 2, 3, 5 4570 1.5 334*B0 334*B0A 470 000 2, 3, 5 4570 1.5 474*B0 474*B0A
Notes
Preferred versions for new designs (1) Replace * in SAP by J for 5 %, H for 3 %, G for 2 % (2) RoHS exemption 7(c)-I: electrical and electronic components containing lead in a glass or ceramic other than dielectric ceramic in capacitors, e.g. piezo-electronic devices, or in a glass or ceramic matrix compound
DIMENSIONS
in millimeters
POWER DERATING
B T
Power derating curve
P (%) 100 H2 H1 P L d 0 - 40 0 55 85 125 150 T (°C) amb
Note
• Zero power is considered as measuring power max. 1 % of max. power. Voltage on the NTC should always be below 50 VDC
PHYSICAL DIMENSIONS FOR RELEVANT TYPE
(all dimensions in millimeters)
R H1 25-VALUE BMAX. d H2 MAX. L P TMAX. MIN. MAX.
3.3 Ω to 220 Ω 5.0 0.6 ± 0.06 1.0 4.0 6.0 24 ± 1.5 2.54 4.0 330 Ω to 470 kΩ 3.3 ± 0.5 0.6 ± 0.06 1.0 3.0 6.0 24 ± 1.5 2.54 3.0 Revision: 29-Jan-2024
2
Document Number: 29049 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
