Datasheet NTCLE100E3 (Vishay) - 3
Manufacturer | Vishay |
Description | NTC Thermistors, Radial Leaded, Standard Precision |
Pages / Page | 17 / 3 — NTCLE100E3. TEMPERATURE DEVIATION AS A FUNCTION. OF THE AMBIENT … |
File Format / Size | PDF / 226 Kb |
NTCLE100E3. TEMPERATURE DEVIATION AS A FUNCTION. OF THE AMBIENT TEMPERATURE
NTCLE100E3
www.vishay.com Vishay BCcomponents
TEMPERATURE DEVIATION AS A FUNCTION TEMPERATURE DEVIATION AS A FUNCTION OF THE AMBIENT TEMPERATURE OF THE AMBIENT TEMPERATURE
3.0 5 1 Curves valid for 2.2 k ΔT Ω to 10 kΩ 1 Curves valid for 12 kΩ to 22 kΩ ΔT (K) Curve 1: ΔR Curve 1: ΔR 25/R25 = 5 % 25/R25 = 5 % (K) Curve 2: 2.5 ΔR Curve 2: ΔR 25/R25 = 3 % 25/R25 = 3 % Curve 3: ΔR 4 Curve 3: ΔR 25/R25 = 2 % 25/R25 = 2 % 2 Curve 4: ΔR25/R25 = 1 % 2 (for NTCLE203E3 series only) 3 2.0 3 3 1.5 4 2 1.0 1 0.5 0 0 - 40 0 40 80 120 160 - 40 0 40 80 120 160 T (°C) T (°C)
4.0 4.0 1 ΔT ΔT 1 Curves valid for 68 kΩ to 100 kΩ Curves valid for 33 kΩ to 47 kΩ (K) (K) Curve 1: ΔR Curve 1: 25/R25 = 5 % 3.5 ΔR25/R25 = 5 % 3.5 Curve 2: ΔR Curve 2: ΔR 25/R25 = 3 % 25/R25 = 3 % Curve 3: ΔR 2 Curve 3: ΔR 25/R25 = 2 % 25/R25 = 2 % 3.0 3.0 2 Curve 4: ΔR Curve 4: ΔR 25/R25 = 1 % 25/R25 = 1 % (for NTCLE203E3 series only) 3 (for NTCLE203E3 series only) 3 2.5 2.5 4 4 2.0 2.0 1.5 1.5 1.0 1.0 0.5 0.5 0 0 - 40 0 40 80 120 160 - 40 0 40 80 120 160 T (°C) T (°C)
6 4.0 Curves valid for 150 kΩ to 220 kΩ Δ ΔT T Curves valid for 330 kΩ to 470 kΩ Curve 1: (K) 1 (K) ΔR Curve 1: ΔR 25/R25 = 5 % 25/R25 = 5 % 3.5 1 Curve 2: ΔR Curve 2: ΔR 25/R25 = 3 % 5 25/R25 = 3 % Curve 3: ΔR Curve 3: ΔR 25/R25 = 2 % 25/R25 = 2 % 3.0 2 2 4 3 3 2.5 3 2.0 1.5 2 1.0 1 0.5 0 0 - 40 0 40 80 120 160 - 40 0 40 80 120 160 T (°C) T (°C) Revision: 29-Jan-2024
3
Document Number: 29049 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
