Datasheet V275LA4P (Littelfuse) - 5
Manufacturer | Littelfuse |
Description | Metal-Oxide Varistors |
Pages / Page | 13 / 5 — Metal-Oxide Varistors. Transient V-I Characteristics Curves. Pulse Rating … |
File Format / Size | PDF / 1.6 Mb |
Metal-Oxide Varistors. Transient V-I Characteristics Curves. Pulse Rating Curves. Maximum Clamping Voltage for 7mm Parts
(MOVs) Radial Lead Varistors > LA Varistor Series
Transient V-I Characteristics Curves Pulse Rating Curves Maximum Clamping Voltage for 7mm Parts Repetitive Surge Capability for 7mm Parts Transient V130LA1(P) - V30 V-I Char 0LA2(P) acteristics Curves V130LA1(P) - V480LA7(P)
6,000 4,000 5,000 MAXIMUM CLAMPING VOLTAGE 2,000 MAXIMUM CLAMPING VOLTAGE 5,000 3,000 1 MODEL SIZE 7mm MODEL SIZE 7mm 1 MODEL SIZE 10mm 4,000 MODEL SIZE 7mm 130 TO 300V 1,000 V130LA5(P) - V680LA10(P) M(AC) RATING 130 TO 300VM(AC) RATING V130LA1(P) - V480LA7(P) 2,000 2 2 3,000 TA = -55oC TO 85oC 2,000 T 500 A = -55oC TO 85oC V300LA4(P) V275LA4(P) 1,000 102 15 V250LA4(P) 103 103 15 2,000 200 104V230LA4(P) 500 104 LTS (V) T (A) LTS (V) 1,000 102 105 T (A) 105 100 106 106 VO V275LA2(P) VO 900 200 V250LA2(P) 800 700 50 1,000 600 100 900 800 500 V300LA2(P) 50 700 400 20 600 10 500 300 SURGE CURREN 20 SURGE CURREN MAXIMUM PEAK 400 5 INDEFINITE V175LA2(P) INDEFINITE V150LA1(P) MAXIMUM PEAK 200 10 V150LA2(P) 300 V140LA2(P) 2 5 V130LA1(P) V130LA2(P) 200 100 1 220 100 1,000 10,000 10-3 10-2 10-1 100 101 102 103 104 10 20 -3 10-2 10 10 0 -1 100 101 1,000 102 10310, 10 000 4
Transient Figure 3 V-I Characteristics Curves
IMPULSE DURATION (
Figure 4
μs) IMPULSE DURATION (μs) PEAK AMPERES (A) PEAK AMPERES (A)
FIGURE 14. SURGE CURRENT RATING CURVES FOR FIGURE 15. SURGE CURRENT RATING CURVES FOR 6,000 4,000 FIGURE 3.
V130LA2(P) - V30
CLAMPING
0LA4(P)
VO
Note:
Repetitive surge capability is qualified and tested based on 8/20us current waveform (not combination MAXIMUM CLAMPING LTA VO GE FOR LTAGE V130LA1(P) - V300LA2(P) FIGURE 4. CLAMPING V1 VO MAXIMUM CLAMPING VO 30LA1(P) - LTA LT GE FOR AGE V480LA7(P) V130LA2(P) - V300LA4(P) 5,000 V130LA5(P) - V680LA10(P) waveform) and UL1449 40.7.3 (Edition 4) test condition. 3,000 MODEL SIZE 7mm 6,000 4,000 MODEL SIZE 7mm 4,000 130 TO 300VM(AC) RATING 130 TO 300VM(AC) RATING 5,000 MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE 5,000 5,000 MODEL SIZE 7mm 3,000 T 3,000 A = -55oC TO 85oC 2,000 T MODEL SIZE 7mm A = -55oC TO 85oC V300LA4(P) 1 1 4,000 6,000 V275LA4(P) MODEL SIZE 14mm MODEL SIZE 14mm 130 TO 300VM(AC) RATING MAXIMUM CLAMPING 130 TO 300VM(AC) RA VOLTA TING GE 2,000 2 V130LA10A(P) - V320LA20A(P) 2,000 2 V385LA20A(P) - V1000LA80A(P) T 5,000 5,000 MAXIMUM CLAMPING VOLTAGE V250LA4(P) 3,000 A = -55oC TO 85oC 2,000 2,000 MODEL SIZE 7mm TA = -55oC TO 85oC V300LA4(P) MODEL SIZE 10mm V230LA4(P) LTS (V) 320 TO 480V V275LA4(P) LTS (V) 4,000 15 102 15 M(AC) RATING 1,0001,000 130 TO 420V V250LA4(P) M(AC) RATING 103 1,000 102 103 2,000 VO T V275LA2(P) VO 900 A = -55oC TO 85oC V250LA2(P) V230LA4(P) 8003,000 T 500 A = -55oC TO 85oC 104 500 104 LTS (V) LTS (V) 1,000 700 105 105 V275LA2(P) 3,000 1,000 900 600 T (A) T (A) VO VO 106 106 900 V250LA2(P) 800 5002,000 200 200 LTS (V) 800 V275LA10(P) 700 V300LA2(P) 1,000 700 400 600 V460LA7(P) LTS (V) V250LA10(P) 900 VO 2,000 600 500 100 V230LA10(P) 100 800 V300LA2(P) 500 V480LA7(P) VO 300 700 400 50 50 600 MAXIMUM PEAK 400 MAXIMUM PEAK 1,000 200 V420LA10(P) V175LA2(P) 300 V150LA1(P) 900 V150LA2(P) 500 800 300 SURGE CURREN 20 V140LA2(P) SURGE CURREN 20 MAXIMUM PEAK 400 MAXIMUM PEAK V175LA2(P) 700 V150LA1(P) 200 V130LA1(P) V150LA2(P) 600 V130LA2(P) INDEFINITE INDEFINITE 1,000 10 10 300 200 V140LA2(P) 100 500 V130LA1(P) MAXIMUM PEAK 10-3 10-2 10-1 100 10 V1 1 10 30LA2(P) 2 103 104 10-3 5 10-2 10-1 100 101 102 103 104 5 V420LA7(P) MAXIMUM PEAK 400 V175LA5(P) 200 100 PEAK AMPERES (A) V385LA7(P) PEAK AMPERES (A) 10-3 10-2 10-1 100 101 102 103 104 10-3 10-2 10-1 100 101 102 103 104 300 V150LA5(P) 2 2 V320LA7(P) V140LA5(P) 20 100 1,000 10,000 20 100 1,000 10,000 PEAK AMPERES (A) FIGURE 3.
Figure 5
CLAMPING VOLTA PEAK GE FOR V130LA1(P) - AMPERES (A) V300LA2(P) FIGURE 4. CLAMPING VOLTAGE FOR V130LA2(P) - V130LA5(P) V300LA4(P) 500 200 IMPULSE DURATION (μs) IMPULSE DURATION (μs)
V320LA7(P)
10-3 10-2
- V480LA7(P)
10-1 100 101 102 104 103 10-3 10-2 10-1 100 101 102 103 104 FIGURE 3. CLAMPING VOLTAGE FOR V130LA1(P) - V300LA2(P) FIGURE 4. CLAMPING VOLTAGE FOR V130LA2(P) - V300LA4(P) FIGURE 16. SURGE CURRENT RATING CURVES FOR FIGURE 17. SURGE CURRENT RATING CURVES FOR PEAK AMPERES (A) PEAK AMPERES (A) 6,000 V130LA10A(P) - V320LA20A(P) V385LA20A(P) - V1000LA80A(P) MAXIMUM CLAMPING VOLTAGE 5,000 MAXIMUM CLAMPING VOLTAGE FIGURE 5. 5,000 CLAMPING MODEL SIZE 7mm VOLTAGE FOR V320LA7(P) - V480LA7(P) FIGURE 6. 10,000 CLAMPING MODEL SIZE 10mm VOLTAGE FOR V130LA5(P) - V420LA10(P) 6,000 10,000 MAXIMUM CLAMPING VOLTAGE 320 TO 480V 4,000 M(AC) RATING 130 TO 1 420V MAXIMUM CLAMPING VOLTAGE M(AC) RATING MODEL SIZE 20mm 1 5,000 5,000 5,000 2 5,000 2 MODEL SIZE 20mm MODEL SIZE 7mm TA = -55oC TO 85oC MODEL SIZE 10mm 3,000 TA = -55oC TO 85oC15 V130LA20A(P) - V320LA40B(P) 15 V385LA40B(P) - V1000LA160B(P) 320 TO 480V 4,000 M(AC) RATING 130 TO 420V 3,000 M(AC) RATING 2,000 102 2,000 102 T 6,000 A = -55oC TO 85oC 3,000 T 103 103 A = -55oC TO 85oC 2,000 LTS (V) MAXIMUM CLAMPING VOLTAGE 1,000 MAXIMUM CLAMPING VOLTAGE V275LA10(P) 104 104 1,000 3,000 5,000 LTS (V) 5,000 MODEL SIZE 10mmV460LA7(P) MODEL SIZE 14mm V250LA10(P) 105 105 VO 2,000 2,000 VO 4,000 500 V230LA10(P) 106 500 106 LTS (V) 300 TO 680V V480LA7(P) V275LA10(P) 130 TO 320V M(AC) RATING M(AC) RATING V680LA10(P) T (A) T (A) V460LA7(P) LTS (V) T V250LA10(P) T VO A = -55oC TO 85oC 3,000 1,000 A = -55oC TO 85oC V420LA1 200 0(P) 2,000 VO V230LA10(P) 900 200 V480LA7(P) 3,000 V625LA10(P) 800100 100 1,000 V420LA10(P) 2,000 700 LTS (V) 900 V660LA10(P) LTS (V) 600 V275LA20A(P) 50 50 1,000 800 V250LA20A(P) VO 500 V300LA20A(P) 2,000 700 V300LA10(P) VO V230LA20A(P) MAXIMUM PEAK 600 V320LA10(P) MAXIMUM PEAK 400 V1 20 75LA5(P)V320LA20A(P) V420LA7(P) 20 1,000 500 SURGE CURREN 1,000 V385LA7(P) INDEFINITE SURGE CURREN INDEFINITE 300 900 V150LA5(P) 10 10 MAXIMUM PEAK V420LA7(P) MAXIMUM PEAK 400 V175LA5(P) V320LA7(P) 800 V140LA5(P) V150LA5(P) 700 5 V130LA5(P) V385LA7(P) 5 500 300 200 600 V320LA7(P) V140LA5(P) 1,000 10-3 10-2 10-1 100 101 102V1 V575LA1 30LA5(P) 0(P) 104 103 500 10-32 10-2 10-1 100 101 102 103 104 2 500
Figure 6
MAXIMUM PEAK 200 PEAK AMPERES (A) V510LA10(P) MAXIMUM PEAK 400 PEAK AMPERES (A) 1 V175LA10A(P) 1 10-3 10-2 10-1 100 101 102 104 103 10-3 10-2 10-1 100 101 102 103 104 V480LA10(P)/ 20 100 1,000 10,000 20 100 1,000 10,000 PEAK AMPERES (A) FIGURE 5. CLAMPING VOLTAGE FOR PEAK AMPERES (A) V460LA1 V320LA7(P) - 0(P) 300 V150LA10A(P) V480LA7(P) FIGURE 6. CLAMPING VOLTAGE FOR V130LA5(P) - IMPULSE DURATION (μs) V140LA1 V420LA1 0A(P) 0(P) IMPULSE DURATION (μs) V385LA10(P) V130LA10A(P) FIGURE 5. CLAMPING VOLTAGE FOR V320LA7(P) - V480LA7(P) 500 200 FIGURE 6. CLAMPING VOLTAGE FOR V130LA5(P) - V420LA10(P) FIGURE 18. SURGE CURRENT RATING CURVES FOR FIGURE 19. SURGE CURRENT RATING CURVES FOR 10-3 10-2 10-1 100 101 102 104 103 10-3 10-2 V1 10-1 30LA20A(P) - 100 101 V320LA40B(P) 102 103 104 V385LA40B(P) - V1000LA160B(P) PEAK AMPERES (A) 6,000 PEAK AMPERES (A) © 2019 Littelfuse, Inc. MAXIMUM CLAMPING VOLTAGE 5,000 MAXIMUM CLAMPING VOLTAGE Specifications are subject to change without notice. 5,000 MODEL SIZE 10mm MODEL SIZE 14mm 6,000 4,000 Revised: 12/17/19 MAXIMUM CLAMPING VOLTAGE FIGURE 7 300 . CLAMPING TO 680V VOLTA MAXIMUM CLAMPING GE FOR VOLTAGE V300LA1 V680LA10(P)0(P) - V680LA10(P) FIGURE 8. 130 CLAMPING TO 320VM(AC) VO RA LTAGE FOR TING V130LA10A(P) - V320LA20A 5,000 M(AC) RATING 5,000 MODEL SIZE 10mm T MODEL SIZE 14mm T A = -55oC TO 85oC 3,000 A = -55oC TO 85oC 4,000 300 TO 680V 130 TO 320V M(AC) RATING M(AC) RATING V680LA10(P) 3,000 T V625LA10(P) TA = -55oC TO 85oC 3,000 A = -55oC TO 85oC 2,000 LTS (V) V660LA10(P) LTS (V) V275LA20A(P) 3,000 V250LA20A(P) V625LA10(P) VO V300LA20A(P) 2,000 2,000 V300LA10(P) VO V230LA20A(P) LTS (V) V660LA10(P) LTS (V) V275LA20A(P) V320LA10(P) V320LA20A(P) V250LA20A(P) V300LA20A(P) 1,000 VO 2,000 V300LA10(P) VO V230LA20A(P) 900 V320LA10(P) V320LA20A(P) 800 1,000 700 900 600 1,000 800 700 V575LA10(P) 500 MAXIMUM PEAK 600 V510LA10(P) MAXIMUM PEAK 400 V175LA10A(P) 1,000 V575LA10(P) 500 V480LA10(P)/ MAXIMUM PEAK MAXIMUM PEAK 400 V460LA10(P) 300 V150LA10A(P) V510LA10(P) V175LA10A(P) V140LA10A(P) V385LA10(P) V480LA10(P)/ V130LA10A(P) V460LA10(P) 500 300 V150LA10A(P) 200 10-3 10-2 10-1 100 101 102V140LA1 10 0A(P) 4 103 V385LA10(P) 10-3 10-2 10-1 100 101 102 103 104 V130LA10A(P) 500 200 PEAK AMPERES (A) PEAK AMPERES (A) 10-3 10-2 10-1 100 101 102 104 103 10-3 10-2 10-1 100 101 102 103 104 PEAK AMPERES (A) FIGURE 7. CLAMPING VOLTAGE FOR PEAK V300LA1 AMPERES (A) 0(P) - V680LA10(P) FIGURE 8. CLAMPING VOLTAGE FOR V130LA10A(P) - V320LA20A FIGURE 7. CLAMPING VOLTAGE FOR V300LA10(P) - V680LA10(P) FIGURE 8. CLAMPING VOLTAGE FOR V130LA10A(P) - V320LA20A
