Datasheet V275LA4P (Littelfuse) - 6
Manufacturer | Littelfuse |
Description | Metal-Oxide Varistors |
Pages / Page | 13 / 6 — Transient V-I Characteristics Curves. Metal-Oxide Varist. ors. Transient … |
File Format / Size | PDF / 1.6 Mb |
Transient V-I Characteristics Curves. Metal-Oxide Varist. ors. Transient V-I Characteristics Curves (Continued...)
Transient V-I Characteristics Curves Transient V-I Characteristics Curves
6,000 4,000 5,000 MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE 3,000 MODEL SIZE 7mm 6,000 4,000 4,000 MODEL SIZE 7mm 130 TO 300V MAXIMUM CLAMPING VOLTAGE M(AC) RATING 130 TO 300V MAXIMUM CLAMPING VOLTAGE M(AC) RATING 5,000 MODEL SIZE 7mm 3,000 3,000 TA = -55oC TO 85o MODEL SIZE 7mm C 2,000 TA = -55oC TO 85oC V300LA4(P) 4,000 V275LA4(P) 130 TO 300VM(AC) RATING 130 TO 300VM(AC) RATING V250LA4(P) 3,000 TA = -55oC TO 85oC 2,000 2,000 TA = -55oC TO 85oC V300LA4(P) V230LA4(P) LTS (V) V275LA4(P) LTS (V) 1,000 V250LA4(P) 2,000 VO V275LA2(P) VO 900 V250LA2(P) V230LA4(P) 800 LTS (V) LTS (V) 1,000 700 V275LA2(P) 1,000 900
Metal-Oxide Varist
600
ors
(MOVs) VO VO 900 V250LA2(P) 800 800 500 700 V300LA2(P) 1,000 700 600 Radial Lead Varistors > LA V 400 aristor Series 900 600 800 500 V300LA2(P) 500 300 700 400 600 MAXIMUM PEAK 400 V175LA2(P) 300 V150LA1(P) MAXIMUM PEAK 200 V150LA2(P) 500 300 V140LA2(P) MAXIMUM PEAK 400 V175LA2(P) V150LA1(P) MAXIMUM PEAK 200 V130LA1(P) V130LA2(P) V150LA2(P) 300 200 V140LA2(P) 100 V130LA1(P) 10-3 10-2 10-1 100 10 V1 1 10 30LA2(P) 2 103 104 10-3 10-2 10-1 100 101 102 103 104 200 100 PEAK AMPERES (A) PEAK AMPERES (A)
Transient V-I Characteristics Curves (Continued...) Pulse Rating Curves (Continued...)
10-3 10-2 10-1 100 101 102 103 104 10-3 10-2 10-1 100 101 102 103 104 PEAK AMPERES (A) FIGURE 3. CLAMPING VOLTA PEAK GE FOR V130LA1(P) - AMPERES (A) V300LA2(P) FIGURE 4. CLAMPING VOLTAGE FOR V130LA2(P) - V300LA4(P) FIGURE 3. CLAMPING VOLTAGE FOR V130LA1(P) - V300LA2(P)
Maximum Clamping
FIGURE 4.
V
CLAMPING
oltag
VOLTA
e for 1
GE FOR
0mm P
V130LA2
arts
(P) - V300LA4(P)
Repetitive Surge Capability for 10mm Parts
6,000 MAXIMUM CLAMPING
V130LA5(P) - V420LA10(P)
VOLTAGE
V130LA5(P) - V680LA10(P)
5,000 5,000 MAXIMUM CLAMPING VOLTAGE MODEL SIZE 7mm MODEL SIZE 10mm 6,000320 TO 480V 4,000 MAXIMUM CLAMPING VOLTAGE 2,000 M(AC) RATING 130 TO 420V MAXIMUM CLAMPING VOLTAGE 5,000 M(AC) RATING 5,000 5,000 MODEL SIZE 7mm TA = -55o 1 C TO 85oC MODEL SIZE 10mm MODEL SIZE 7mm 3,000 1 T MODEL SIZE 10mm A = -55oC TO 85oC 320 TO 480V 4,000 1,000 V130LA5(P) - V680LA10(P) M(AC) RATING V130LA1(P) - V480LA7(P) 3,000 130 TO 420VM(AC) RATING 2,000 T 2 2 A = -55oC TO 85oC 3,000 500 TA = -55oC TO 85oC 2,000 LTS (V) V275LA10(P) 1,000 102 3,000 15 V460LA7(P) LTS (V) 103 V250LA1 103 0(P) VO 2,000 200 104 500 15 V230LA1 104 0(P) 2,000 V480LA7(P) VO LTS (V) V275LA10(P) 102 105 105 V460LA7(P) LTS (V) T (A) V250LA10(P) T (A) 100 106 1,000 VO V420LA10(P) 106 2,000 VO V230LA10(P) 900 200 V480LA7(P) 800 50 1,000 700 V420LA10(P) 100 900 600 1,000 800 20 500 50 700 MAXIMUM PEAK 600 V420LA7(P) MAXIMUM PEAK 400 V175LA5(P) 1,000 SURGE CURREN 500 10 20 V385LA7(P) SURGE CURREN 300 V150LA5(P) MAXIMUM PEAK MAXIMUM PEAK 400 5 V175LA5(P) INDEFINITE V320LA7(P) INDEFINITE V140LA5(P) V420LA7(P) 10 V130LA5(P) V385LA7(P) 500 300 V150LA5(P) 200 5 V320LA7(P) 2 10-3 10-2 10-1 100 101 102 V1 10 40LA5(P) 4 103 10-3 10-2 10-1 100 101 102 103 104 V130LA5(P) 500 200 PEAK AMPERES (A) 1 2 PEAK AMPERES (A) 10-3 10-2 10-1 100 101 102 104 103 10 20-3 10-2 10 100 -1 100 1011,000 102 103 1 10 0, 4 000 20 100 1,000 10,000 PEAK AMPERES (A) IMPULSE DURATION ( FIGURE 5.
Figure 7
CLAMPING VOLTAGE FOR PEAK IMPULSE DURA V320LA7(P) - AMPERES (A) TION (μs) V480LA7(P) FIGURE 6.
Figure 8
CLAMPING VOLTAGE FOR V130LA5(P) - μs) V420LA10(P) FIGURE 14. SURGE CURRENT RATING CURVES FOR FIGURE
Note:
15. SURGE CURRENT RATING CURVES FOR
V300LA10(P) - V680LA10(P)
Repetitive surge capability is qualified and tested based on 8/20us current waveform (not combination FIGURE 5. CLAMPING VOLTAGE FOR V320LA7(P) - V480LA7(P) FIGURE 6. CLAMPING VOLTAGE FOR V130LA5(P) - V420LA10(P) V130LA1(P) - V480LA7(P) V130LA5(P) - V680LA1 waveform) and UL1449 40.7.3 (Edition 4) test condition. 0(P) 6,000 MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE 5,000 5,000 5,000 5,000 MODEL SIZE 1 1 0mm MODEL SIZE 1 1 4mm 6,000 MODEL SIZE 14mm 4,000 MODEL SIZE 14mm 300 TO 2 680V 130 TO 320V MAXIMUM CLAMPING VOLTAGE M(AC) RATING 2 M(AC) RATING 2,000 MAXIMUM CLAMPING VOLTAGE V1 V680LA1 30LA1 0(P) 0A(P) - V320LA20A(P) 2,000 V385LA20A(P) - V1000LA80A(P) 5,000 5,000 MODEL SIZE 10mm T T A = -55oC TO 85o MODEL SIZE 1 C 4mm 3,000 A = -55oC TO 85oC 4,000 300 TO 680V 1,000 130 15 TO 320V 102 15 M(AC) RATING V680LA10(P) 1,000 102 3,000 M(AC) RATING V625LA10(P) 103 103 T 3,000 TA = -55oC TO 85oC 2,000 A = -55oC TO 85oC 104 104 LTS (V) 500 V660LA10(P) 105 LTS (V) 500 V275LA20A(P) T (A) T (A) V250LA20A(P) 105 3,000 V625LA10(P) VO 106 V300LA20A(P) 106 2,000 V300LA10(P) 2,000 VO V230LA20A(P) LTS (V) V660LA10(P) LTS (V) 200 200 V320LA10(P) V275LA20A(P) V320LA20A(P) V250LA20A(P) 1,000 VO V300LA10(P) VO V300LA20A(P) 100 V230LA20A(P) 900 2,000 100 V320LA20A(P) 800 V320LA10(P) 1,000 50 700 50 900 600 1,000 800 V575LA10(P) 500 SURGE CURREN 700 20 SURGE CURREN 20 MAXIMUM PEAK 600 V510LA10(P) MAXIMUM PEAK 400 INDEFINITE V175LA10A(P) INDEFINITE 1,000 V575LA10(P) 500 10 V480LA10(P)/ 10 V460LA10(P) 300 V150LA10A(P) MAXIMUM PEAK V510LA10(P) MAXIMUM PEAK 4005 V175LA10A(P) 5 V140LA10A(P) V385LA10(P) V480LA10(P)/ V130LA10A(P) 500 V150LA10A(P) 200 V460LA10(P) 3002 10-3 10-2 10-1 100 101 102V140LA1 104 103 0A(P) 2 10-3 10-2 10-1 100 101 102 103 104 V385LA10(P) 20 100 1,000 10,000 20 100 1,000 10,000
Figur
200
e 9
PEAK AMPERES (A) V130LA10A(P) 500 PEAK AMPERES (A) IMPULSE DURATION (μs) IMPULSE DURATION (μs) 10-3 10-2 10-1 100 101 102 104 103 10-3 10-2 10-1 100 101 102 103 104 PEAK AMPERES (A) FIGURE 7. FIGURE CLAMPING 16. VOLTAGE FOR PEAK SURGE CURRENT RA V300LA1 AMPERES (A) TING 0(P) - V680LA1 CURVES FOR 0(P) FIGURE 8. CLAMPING FIGURE 17. VOLTAGE FOR SURGE CURRENT V1 RA 30LA1 TING 0A(P) - V320LA20A CURVES FOR V130LA10A(P) - V320LA20A(P) V385LA20A(P) - V1000LA80A(P) FIGURE 7. CLAMPING VOLTAGE FOR V300LA10(P) - V680LA10(P) FIGURE 8. CLAMPING VOLTAGE FOR V130LA10A(P) - V320LA20A 10,000 10,000 1 1 5,000 2 MODEL SIZE 20mm 5,000 2 MODEL SIZE 20mm 15 V130LA20A(P) - V320LA40B(P) 15 V385LA40B(P) - V1000LA160B(P) 2,000 102 102 103 2,000 103 104 1,000 104 1,000 105 105 500 106 500 106 T (A) T (A) 200 200 100 100 50 50 20 20 SURGE CURREN INDEFINITE INDEFINITE 10 SURGE CURREN 10 5 5 2 2 1 1 20 100 1,000 10,000 20 100 1,000 10,000 IMPULSE DURATION (μs) IMPULSE DURATION (μs) FIGURE 18. SURGE CURRENT RATING CURVES FOR FIGURE 19. SURGE CURRENT RATING CURVES FOR V130LA20A(P) - V320LA40B(P) V385LA40B(P) - V1000LA160B(P) © 2019 Littelfuse, Inc. Specifications are subject to change without notice. Revised: 12/17/19
