Datasheet MAX4165, MAX4166, MAX4167, MAX4168, MAX4169 (Analog Devices) - 6
DescriptionHigh-Output-Drive, Precision, Low-Power, Single-Supply, Rail-to-Rail I/O Op Amps with Shutdown
Pages / Page17 / 6 — High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O …
High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O Op Amps with Shutdown
High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O Op Amps with Shutdown ____________________________Typical Operating Characteristics (continued)
(VCC = +5.0V, VEE = 0V, RL = 100kΩ, TA = +25°C, unless otherwise noted.)
MINIMUM OPERATING VOLTAGE COMMON-MODE REJECTION RATIO LARGE-SIGNAL GAIN vs. OUTPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE (SINKING, VCC = 6.5V)
2.00 88.0 140 RL = 100kΩ 87.5 MAX4165-09 MAX4165-10 120 MAX4165-11 1.95 87.0 R 100 L = 1kΩ 1.90 86.5 R 80 L = 100Ω 86.0 60 1.85 CMRR (dB) 85.5 40 85.0 LARGE-SIGNAL GAIN (dB) 1.80 MINIMUM OPERATING VOLTAGE (V) 84.5 20 VCC = +6.5V RL to VCC
MAX4165–MAX4169
1.75 84.0 0 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 0 0.1 0.2 0.3 0.4 0.5 0.6 TEMPERATURE (°C) TEMPERATURE (°C) OUTPUT VOLTAGE (V)
LARGE-SIGNAL GAIN vs. OUTPUT VOLTAGE LARGE-SIGNAL GAIN vs. OUTPUT VOLTAGE LARGE-SIGNAL GAIN vs. OUTPUT VOLTAGE (SOURCING, VCC = 6.5V) (SINKING, VCC = 2.7V) (SOURCING, VCC = 2.7V)
125 120 120 R 120 L = 100kΩ RL = 100kΩ R MAX4165-12 100 MAX4165-13 100 L = 100kΩ MAX4165-14 RL = 1kΩ 115 80 80 R RL = 1kΩ L = 100Ω R 110 R L = 100Ω L = 1kΩ 60 60 105 RL = 100Ω 40 40 100 LARGE-SIGNAL GAIN (dB) LARGE-SIGNAL GAIN (dB) LARGE-SIGNAL GAIN (dB) 95 20 20 V V CC = +6.5V V CC = +2.7V CC = +2.7V R R L to VEE R L to VEE L to VCC 90 0 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0 0.05 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0 0.05 0.10 0.15 0.20 0.25 0.30 0.36 0.40 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V)
LARGE-SIGNAL GAIN vs. TEMPERATURE LARGE-SIGNAL GAIN vs. TEMPERATURE OUTPUT VOLTAGE LOW (R (R L = 100
) L = 100k
) vs. TEMPERATURE
110 125 120 VCC = +6.5V VOUTp-p = VCC - 1V RL to VCC 105 RL to VEE 123 R MAX4165-15 L = 100kΩ MAX4165-15a 100 MAX4165-16 100 121 VCC = +6.5V, RL = 100Ω 95 119 80 V 90 CC = +6.5V 117 (mV) RL to VCC or VEE EE 85 60 115 - V VCC = +2.7V, RL = 100Ω 80 VCC = +6.5V VCC = +2.7V R VCC = +2.7V V OUT L to VCC 113 40 75 R LARGE-SIGNAL GAIN (dB) L to VCC RL to VEE LARGE-SIGNAL GAIN (dB) VCC = +6.5V, RL = 100kΩ 111 70 VCC = +2.7V V 20 V OUTp-p = VCC - 1V CC = +2.7V, RL = 100kΩ 109 RL to VCC or VEE 65 RL = 100Ω 60 107 0 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
6 _______________________________________________________________________________________
