Datasheet KMA210 (NXP)
ManufacturerNXP
DescriptionProgrammable Angle Sensor
Pages / Page37 / 1 — KMA210 Programmable angle sensor. Rev. 2 — 7 December 2011. Product data …
File Format / SizePDF / 586 Kb
KMA210 Programmable angle sensor. Rev. 2 — 7 December 2011. Product data sheet. 1. Product. profile. 1.1 General description
Datasheet KMA210 NXP
KMA210 Programmable angle sensor Rev. 2 — 7 December 2011 Product data sheet 1. Product profile 1.1 General description
The KMA210 is a magnetic angle sensor module. The MagnetoResistive (MR) sensor bridges, the mixed signal Integrated Circuit (IC) and the required capacitances are integrated into a single package. This angular measurement module KMA210 is pre-programmed, pre-calibrated and therefore, ready to use. The KMA210 allows user-specific adjustments of angular range, zero angle and clamping voltages. The settings are stored permanently in a non-volatile memory.
1.2 Features and benefits
High precision sensor for magnetic High temperature range up to 160 C angular measurement Single package sensor module with Ratiometric analog output voltage integrated filters for improved ElectroMagnetic Compatibility (EMC) Automotive qualified in accordance with Overvoltage protection up to 16 V AEC-Q100 Rev-G Programmable user adjustments, Programming via One-Wire Interface including zero angle and angular range (OWI) Fail-safe non-volatile memory with write User-programmable 32-bit identifier protection using lock bit Independent from magnetic field Magnet-loss, power-loss and broken strength above 35 kA/m bond wire detection Ready to use without external Factory calibrated components Document Outline 1. Product profile 1.1 General description 1.2 Features and benefits 2. Pinning information 3. Ordering information 4. Functional diagram 5. Functional description 5.1 Angular measurement directions 6. Analog output 7. Diagnostic features 7.1 CRC and EDC supervision 7.2 Magnet-loss detection 7.3 Power-loss detection 7.4 Broken bond wire detection 7.5 Low supply voltage detection and overvoltage protection 8. Limiting values 9. Recommended operating conditions 10. Thermal characteristics 11. Characteristics 12. Definition of errors 12.1 General 12.2 Hysteresis error 12.3 Linearity error 12.4 Microlinearity error 12.5 Temperature drift error 12.6 Angular error 13. Programming 13.1 General description 13.2 Timing characteristics 13.3 Sending and receiving data 13.3.1 Write access 13.3.2 Read access 13.3.3 Entering the command mode 13.4 Cyclic redundancy check 13.4.1 Software example in C 13.5 Registers 13.5.1 Command registers 13.5.2 Non-volatile memory registers 14. Electromagnetic compatibility 14.1 Emission (CISPR 25) 14.1.1 Conducted radio disturbance 14.1.2 Radiated radio disturbance 14.2 Radiated disturbances (ISO 11452-1 third edition (2005-02), ISO 11452-2, ISO 11452-4 and ISO 11452-5) 14.2.1 Absorber lined shielded enclosure 14.2.2 Bulk-current injection 14.2.3 Strip line 14.2.4 Immunity against mobile phones 14.3 Electrical transient transmission by capacitive coupling [ISO 7637-3, second edition (2007-07)] 15. ElectroStatic Discharge (ESD) 15.1 Human body model (AEC-Q100-002) 15.2 Human metal model (ANSI/ESD SP5.6-2009) 15.3 Machine model (AEC-Q100-003) 15.4 Charged-device model (AEC-Q100-011) 16. Application information 17. Test information 17.1 Quality information 18. Marking 19. Terminals 20. Package outline 21. Handling information 22. Solderability information 23. Revision history 24. Legal information 24.1 Data sheet status 24.2 Definitions 24.3 Disclaimers 24.4 Trademarks 25. Contact information 26. Contents
