Datasheet ADRF5010 (Analog Devices) - 6
DescriptionSilicon SPST Switch, NonReflective, 100 MHz to 55 GHz
Pages / Page12 / 6 — ADRF5010. ABSOLUTE MAXIMUM RATINGS. ELECTROSTATIC DISCHARGE (ESD) …
File Format / SizePDF / 665 Kb
ADRF5010. ABSOLUTE MAXIMUM RATINGS. ELECTROSTATIC DISCHARGE (ESD) RATINGS. ESD CAUTION
ADRF5010 ABSOLUTE MAXIMUM RATINGS ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD CAUTION
Data Sheet
The following ESD information is provided for handling of ESD-sen-
ESD (electrostatic discharge) sensitive device
. Charged devi- sitive devices in an ESD protected area only. ces and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, Human body model (HBM) per ANSI/ESDA/JEDEC JS-001. damage may occur on devices subjected to high energy ESD. Charged device model (CDM) ratings are per ANSI/ESDA/JEDEC Therefore, proper ESD precautions should be taken to avoid JS-002. performance degradation or loss of functionality.
Table 5. ADRF5010, 14-Terminal LGA ESD Model Withstand Threshold (V) Class
HBM 750 for RF pins 1B 750 for supply and digital 1B control pins CDM 500 for all pins C2A
analog.com Rev. 0 | 6 of 12
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curves Electrostatıc Dıscharge (ESD) Ratıngs ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input And Output Applications Information Evaluation Board Recommendatıons For Printed Circuit Board Design Outline Dimensions Ordering Guide Evaluation Boards
