XC6505 Series, LDO with Extended Temperature Range
Torex Semiconductor XC6505
The new XC6505 series from Torex is a 10.5V LDO that combines the best of both worlds, being high speed (its PSRR is 60dB @1kHz) while consuming only 5.5µA. The XC6505 operates with input voltages from 1.7V to 10.5V over the extended -40~+105°C temperature range, can deliver output currents up to 200mA and is readily available with fixed output voltages from 1.5V to 8.0V in 0.1V increments.
Torex - XC6505
Other characteristics of the XC6505 include a high output voltage accuracy of ±1% for VOUT≥2.0V (±20mV for VOUT<2.0V) and a low voltage dropout of 190mV @ 100mA (VOUT=3.3V).
Key Features:
  • Input Voltage: 1.7V ~10.5V
  • Output Voltage: 1.5V ~ 8.0V (0.1V steps)
  • Max. Output current: 200mA
  • Ripple Rejection Rate: 60dB @ 1kHz
  • Low supply current: 5.5μA
  • Standby current: <0.1μA
  • Op. Temp Range: -40ºC~105ºC
torex-europe.com
