Triple Output 28 V Step-Down μModule Regulator with Integrated Heatsink delivers 70 W in 4.5 cm²
Linear Technology LTM4634
Linear Technology Corporation introduces the LTM4634, a triple output step-down μModule® (micromodule) regulator in a 15 mm × 15 mm × 5.01 mm BGA package with integrated heat sink. The thermally efficient package enables the LTM4634 to deliver full current on all three outputs (5 A, 5 A, and 4 A), more than 70 W of output power at 65 °C ambient with 200 LFM airflow. Combined with only 13 ceramic capacitors and three resistors, the LTM4634 solution fits within 4.5 cm2 on a dual-sided PCB. The LTM4634 includes three DC/DC controllers, power switches, inductors and compensation in a single package. The regulated output voltage for channels 1 and 2 is adjustable between 0.8 V to 5.5 V, with the third channel from 0.8 V to 13.5 V, each with ±1.5% accuracy over line, load and temperature. The combination of wide output voltage range, a thermally efficient package, tight regulation accuracy and small solution size makes the LTM4634 well suited to regulate common intermediate power buses such as 12 V, 5 V and 3.3 V in instrumentation, communications and industrial applications.
Linear Technology - LTM4634
The LTM4634’s three switchers operate from an input voltage from 4.75 V to 28 V. Separate input power pins for each switcher enables channel one and/or channel two to be supplied from a 12.5 V, 50 W intermediate bus generated from channel three. The three switchers, operating from the same internal or optional external clock signal, are internally phase shifted by 120° to minimize input ripple. For loads in excess of 5 A, channels 1 and 2 can be paralleled to support up to 10 A. Output overvoltage and overcurrent fault protection are included in the regulator. The LTM4634's internal temperature can be observed via two internal temperature diode monitors located next to the power stages.
The LTM4634 is available in the –40 °C to +125 °C internal operating temperature grade for immediate delivery from stock. Pricing starts at $35.95 each for 1,000-piece quantities.
Summary of Features: LTM4634
  • Triple Output, 28 V , 70 W Step-Down Solution in Less Than 4.5 cm²
    • Only a Few Ceramic Capacitors & Resistors Required for a Complete Solution
  • 15 × 15 × 5.01 mm BGA with Integrated Heat Sink
  • Full Output Current (5 A, 5 A, 4 A) on All Channels at 65 °C Ambient with 200 LFM Airflow, no External Heatsink
  • 4.75 V to 28 V Operating VIN Range with Separate Inputs for each Channel
  • ±1.5% Accurate User Adjustable VOUT Between:
    • Channel 1: 0.8 V to 5.5 V
    • Channel 2: 0.8 V to 5.5 V
    • Channel 3: 0.8 V to 13.5 V
  • Channel 1 & Channel 2 Can Be Paralleled to Deliver up to 10 A
