Datasheet AD8479
DescriptionVery High Common-Mode Voltage Precision Difference Amplifier
Pages / Page17 / 1 — Very High Common-Mode Voltage. Precision Difference Amplifier. Data …
File Format / SizePDF / 464 Kb
Very High Common-Mode Voltage. Precision Difference Amplifier. Data Sheet. AD8479. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet AD8479
Very High Common-Mode Voltage Precision Difference Amplifier Data Sheet AD8479 FEATURES FUNCTIONAL BLOCK DIAGRAM ±600 V common-mode voltage range AD8479 Rail-to-rail output REF(–) 1 8 NC Fixed gain of 1 Wide power supply range of ±2.5 V to ±18 V 7 +V 1MΩ S 550 μA typical power supply current –IN 2 Excellent ac specifications 6 OUTPUT 90 dB minimum CMRR +IN 3 1MΩ 130 kHz bandwidth –V 4 S High accuracy dc performance 5 REF(+) 5 ppm maximum gain nonlinearity 10 µV/°C maximum offset voltage drift
001
NOTES
18-
5 ppm/°C maximum gain drift 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
111 Figure 1.
APPLICATIONS High voltage current sensing Battery cell voltage monitors Power supply current monitors Motor controls Isolation GENERAL DESCRIPTION
The AD8479 is a difference amplifier with a very high input
800
common-mode voltage range. The AD8479 is a precision device
VS = ±15V 600
that allows the user to accurately measure differential signals in the presence of high common-mode voltages up to ±600 V.
400 E (V) G VS = ±5V A
The AD8479 can replace costly isolation amplifiers in applications
200 LT
that do not require galvanic isolation. The device operates over
E VO 0
a ±600 V common-mode voltage range and has inputs that are
D -MO
protected from common-mode or differential mode transients
N –200
up to ±600 V.
MMO –400 O C
The AD8479 has low offset voltage, low offset voltage drift,
–600
low gain drift, low common-mode rejection drift, and excellent common-mode rejection ratio (CMRR) over a wide frequency
–800
10 1 range.
–20 –15 –10 –5 0 5 10 15 20
18-
VOUT (V)
111 The AD8479 is available in a space-saving 8-lead SOIC package Figure 2. Input Common-Mode Voltage vs. Output Voltage and is operational over the −40°C to +125°C temperature range.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Single-Supply Operation System-Level Decoupling and Grounding Using a Large Shunt Resistor Output Filtering Gain of 60 Differential Amplifier Error Budget Analysis Example Outline Dimensions Ordering Guide
