Datasheet AD8479 - 5
DescriptionVery High Common-Mode Voltage Precision Difference Amplifier
Pages / Page17 / 5 — AD8479. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. …
File Format / SizePDF / 464 Kb
AD8479. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
AD8479 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
AD8479 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these Supply Voltage, VS ±18 V or any other conditions above those indicated in the operational Input Voltage Range section of this specification is not implied. Operation beyond Continuous ±600 V the maximum operating conditions for extended periods may Common-Mode and Differential, ±900 V 10 sec affect product reliability. Output Short-Circuit Duration Indefinite REF(−) and REF(+) −V
ESD CAUTION
S − 0.3 V to +VS + 0.3 V Maximum Junction Temperature 150°C Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C Rev. A | Page 4 of 16 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Single-Supply Operation System-Level Decoupling and Grounding Using a Large Shunt Resistor Output Filtering Gain of 60 Differential Amplifier Error Budget Analysis Example Outline Dimensions Ordering Guide
