1.1 Scope. This drawing documents the general requirements of a high performance 105 MHz low power, low noise, rail to rail amplifier microcircuit, with an operating temperature range of -55C to +125C. 1.2 Vendor Item Drawing Administrative Control Number. The manufacturer’s PIN is the item of identification. The vendor item drawing establishes an administrative control number for identifying the item on the engineering documentation: V62/16621 - 01 X E Drawing Device type Case outline Lead finish number (See 1.2.1) (See 1.2.2) (See 1.2.3) 1.2.1 Device type(s).
Device type Generic Circuit function 01 ADA4805-2 105 MHz low power, low noise rail to rail amplifier 1.2.2 Case outline(s). The case outline(s) are as specified herein. Outline letter Number of pins JEDEC PUB 95 Package style X 8 MO-187-AA Small outline package 1.2.3 Lead finishes. The lead finishes are as specified below or other lead finishes as provided by the device manufacturer: Finish designator Material A Hot solder dip B Tin-lead plate C Gold plate D Palladium E Gold flash palladium Z Other 1.3 Absolute maximum ratings. 1/ Supply voltage (VS) .. 11 V Power dissipation (PD) ... See figure 3 Common mode input voltage ... -VS – 0.7 V to +VS + 0.7 V Differential input voltage ... 1 V Storage temperature range (TSTG) .. -65C to +125C Lead temperature (soldering, 10 seconds) ... 300C Junction temperature (TJ) .. 150C Thermal resistance, junction to ambient (JA) .. 123.8C/W Thermal resistance, junction to board (JB) ... 136.8C/W Thermal resistance, junction to case (JC) ... 68.52C/W 1/ Stresses beyond those listed under “absolute maximum rating” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. DLA LAND AND MARITIME SIZE
