Datasheet RH6200M (Analog Devices)
DescriptionLow Noise, High Speed Rail-to-Rail Op Amp
Pages / Page10 / 1 — DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 1). BURN-IN CIRCUIT. …
File Format / SizePDF / 158 Kb
DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 1). BURN-IN CIRCUIT. PACKAGE/ORDER INFORMATION
Datasheet RH6200M Analog Devices
RH6200M Low Noise, High Speed Rail-to-Rail Op Amp
DESCRIPTION ABSOLUTE MAXIMUM RATINGS (Note 1)
The RH6200 is an ultralow noise, rail-to-rail input and Total Supply Voltage (V+ to V–) .. 12.6V output unity-gain stable op amp that features 0.95nV/√Hz Input Current (Note 2) ... ±40mA noise voltage. This amplifier combines very low noise Output Short-Circuit Duration (Note 3) .. Indefinite with a 165MHz gain bandwidth, 50V/μs slew rate and is Pin Current While Exceeding Supplies (Note 4) ...±30mA optimized for low voltage signal conditioning systems. Operating Junction Temperature Range A shutdown pin reduces supply current during standby (Note 5) ... –55°C to 125°C conditions and thermal shutdown protects the part from Storage Temperature Range .. –65°C to 150°C overload conditions. The RH6200 maintains its pre- Lead Temperature (Soldering, 10 sec) ... 300°C irradiation performance for supplies from 4.5V to 12.6V L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear and is specified pre- and post-radiation at 5V and ±5V. Technology Corporation. All other trademarks are the property of their respective owners.
BURN-IN CIRCUIT PACKAGE/ORDER INFORMATION
10k ORDER PART TOP VIEW 6.3V NUMBER SHDN 1 10 NC 3 – 8 RH6200MW NC 2 – 9 NC 7 200Ω –IN 3 8 V+ + 4 + 5 +IN 4 7 OUT 10k V– 5 6 NC –6.3V RH6200M F01 W PACKAGE 10-LEAD CERPAC
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) TA = 25°C SUB- –55°C ≤ TA ≤ 125°C SUB- SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX GROUP MIN TYP MAX GROUP UNITS
VOS Input Offset VS = 5V, 0V; VCM = V– to V+ 0.6 2 1 4 2,3 mV Voltage VS = ±5V; VCM = V– to V+ 2.5 6 1 9 2,3 mV IB Input Bias Current VS = 5V, 0V; VCM = V+ 8 18 1 20 2,3 μA VS = 5V, 0V; VCM = V– –50 –23 1 –100 2,3 μA VS = ±5V; VCM = V+ 8 18 1 20 2,3 μA VS = ±5V; VCM = V– –50 –23 1 –200 2,3 μA IOS Input Offset VS = 5V, 0V; VCM = V+ 0.02 4 1 5 2,3 μA Current VS = 5V, 0V; VCM = V– 0.4 5 1 25 2,3 μA VS = ±5V; VCM = V+ 1 7 1 12 2,3 μA VS = ±5V; VCM = V– 3 12 1 50 2,3 μA rh6200mfa 1
