Datasheet AD8065, AD8066 (Analog Devices) - 5
DescriptionHigh Performance, 145 MHzFastFET Op Amp
Pages / Page28 / 5 — Data Sheet. AD8065/AD8066. Parameter. Conditions. Min. Typ. Max Unit
RevisionL
File Format / SizePDF / 969 Kb
Data Sheet AD8065/AD8066 Parameter Conditions Min Typ Max Unit
OUTPUT CHARACTERISTICS Output Voltage Swing RL = 1 kΩ −4.88 to +4.90 −4.94 to +4.95 V AD8065WARTZ only: TMIN − TMAX −4.88 to +4.90 V RL = 150 Ω −4.8 to +4.7 V Output Current VO = 9 V p-p, SFDR ≥ −60 dBc, f = 500 kHz 35 mA Short-Circuit Current 90 mA Capacitive Load Drive 30% overshoot G = +1 20 pF POWER SUPPLY Operating Range 5 24 V AD8065WARTZ only: TMIN − TMAX 5 10 V Quiescent Current per Amplifier 6.4 7.2 mA AD8065WARTZ only: TMIN − TMAX 7.2 mA Power Supply Rejection Ratio ±PSRR −85 −100 dB AD8065WARTZ only: TMIN − TMAX −85 dB Rev. L | Page 5 of 28 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications ±5 V Specifications ±12 V Specifications +5 V Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Test Circuits SOIC-8 Pinout Theory of Operation Closed-Loop Frequency Response Noninverting Closed-Loop Frequency Response Inverting Closed-Loop Frequency Response Wideband Operation Input Protection Thermal Considerations Input and Output Overload Behavior Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Input-to-Output Coupling Wideband Photodiode Preamp High Speed JFET Input Instrumentation Amplifier Video Buffer Outline Dimensions Ordering Guide Automotive Products
