Datasheet AD8065, AD8066 (Analog Devices)
DescriptionHigh Performance, 145 MHzFastFET Op Amp
Pages / Page28 / 1 — High Performance, 145 MHz. FastFET. Op Amps. Data Sheet. AD8065/. AD8066. …
RevisionL
File Format / SizePDF / 969 Kb
High Performance, 145 MHz. FastFET. Op Amps. Data Sheet. AD8065/. AD8066. FEATURES. APPLICATIONS. Qualified for automotive applications
Datasheet AD8065, AD8066 Analog Devices, Revision: L
High Performance, 145 MHz FastFET Op Amps Data Sheet AD8065/ AD8066 FEATURES APPLICATIONS Qualified for automotive applications Automotive driver assistance systems FET input amplifier Photodiode preamps 1 pA input bias current Filters Low cost A/D drivers High speed: 145 MHz, −3 dB bandwidth (G = +1) Level shifting 180 V/µs slew rate (G = +2) Buffering Low noise CONNECTION DIAGRAMS 7 nV/√Hz (f = 10 kHz) AD8065 AD8065 VOUT 1 5 +VS NC 1 8 NC 0.6 fA/√Hz (f = 10 kHz) Wide supply voltage range: 5 V to 24 V –VS 2 –IN 2 7 +VS Single-supply and rail-to-rail output +IN 3 4 +IN 3 6 –IN VOUT TOP VIEW Low offset voltage 1.5 mV maximum (Not to Scale) –VS 4 5 NC TOP VIEW High common-mode rejection ratio: −100 dB (Not to Scale) Excellent distortion specifications SFDR −88 dBc @ 1 MHz AD8066 V 1 8 OUT1 +VS Low power: 6.4 mA/amplifier typical supply current –IN1 2 7 VOUT2 No phase reversal +IN1 3 6 –IN2 Small packaging: SOIC-8, SOT-23-5, and MSOP-8 –V 4 S 5 +IN2 TOP VIEW (Not to Scale)
02916-E-001 Figure 1.
GENERAL DESCRIPTION
The AD8065/AD8066 are high performance, high speed, FET The AD8065/AD80661 FastFET™ amplifiers are voltage feedback input amplifiers available in small packages: SOIC-8, MSOP-8, amplifiers with FET inputs offering high performance and ease and SOT-23-5. They are rated to work over the industrial of use. The AD8065 is a single amplifier, and the AD8066 is a temperature range of −40°C to +85°C. dual amplifier. These amplifiers are developed in the Analog The AD8065WARTZ-R7 is fully qualified for automotive Devices, Inc. proprietary XFCB process and allow exceptionally applications. It is rated to operate over the extended temperature low noise operation (7.0 nV/√Hz and 0.6 fA/
Hz) as well as range (−40°C to +105°C), up to a maximum supply voltage very high input impedance. range of ±5 V only. With a wide supply voltage range from 5 V to 24 V, the ability to
24
operate on single supplies, and a bandwidth of 145 MHz, the
21 G = +10
AD8065/AD8066 are designed to work in a variety of applications.
VO = 200mV p-p 18
For added versatility, the amplifiers also contain rail-to-rail outputs.
15 G = +5
Despite the low cost, the amplifiers provide excellent overal
12
performance. The differential gain and phase errors of 0.02%
9
and 0.02°, respectively, along with 0.1 dB flatness out to 7 MHz,
G = +2 GAIN (dB)
make these amplifiers ideal for video applications. Additionally,
6
they offer a high slew rate of 180 V/µs, excellent distortion (SFDR
3 G = +1
of −88 dBc @ 1 MHz), extremely high common-mode rejection
0
of −100 dB, and a low input offset voltage of 1.5 mV maximum
–3
under warmed up conditions. The AD8065/AD8066 operate
–6
using only a 6.4 mA/amplifier typical supply current and are
0.1 1 10 100 1000
capable of delivering up to 30 mA of load current.
FREQUENCY (MHz)
02916-E-002 Figure 2. Small Signal Frequency Response 1 Protected by U. S. Patent No. 6,262,633.
Rev. L Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2002–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications ±5 V Specifications ±12 V Specifications +5 V Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Test Circuits SOIC-8 Pinout Theory of Operation Closed-Loop Frequency Response Noninverting Closed-Loop Frequency Response Inverting Closed-Loop Frequency Response Wideband Operation Input Protection Thermal Considerations Input and Output Overload Behavior Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Input-to-Output Coupling Wideband Photodiode Preamp High Speed JFET Input Instrumentation Amplifier Video Buffer Outline Dimensions Ordering Guide Automotive Products
