Datasheet AD8065, AD8066 (Analog Devices) - 3
DescriptionHigh Performance, 145 MHzFastFET Op Amp
Pages / Page28 / 3 — Data Sheet. AD8065/AD8066. REVISION HISTORY. 1/2019—Rev. K to Rev. L. …
RevisionL
File Format / SizePDF / 969 Kb
Data Sheet. AD8065/AD8066. REVISION HISTORY. 1/2019—Rev. K to Rev. L. 8/2016—Rev. J to Rev. K. 2/2004—Rev. D to Rev. E
Data Sheet AD8065/AD8066 REVISION HISTORY 1/2019—Rev K to Rev L 8/2016—Rev J to Rev K 2/2004—Rev D to Rev E
Data Sheet AD8065/AD8066 REVISION HISTORY 1/2019—Rev. K to Rev. L
Changes to General Description ... 1 Changed AD8065WARTZ-REEL7 to Changes to Figure 22 through Figure 27 .. 11 AD8065WARTZ-R7 .. Throughout Updated Outline Dimensions .. 25 Changes to Ordering Guide ... 26
Updated Outline Dimensions .. 27
2/2004—Rev. D to Rev. E.
Changes to Ordering Guide ... 28 Updated Format .. Universal
Updated Figure 56 ... 21
8/2010—Rev. I to Rev. J
Updated Outline Dimensions .. 25 Changes to Features Section, Applications Section, and General Updated Ordering Guide ... 26 Description Section ... 1
Change to Table 1 .. 4
11/2003—Rev. C to Rev. D.
Change to Table 3 .. 7 Changes to Features ... 1 Changes to Table 4 .. 9 Changes to Connection Diagrams ... 1 Changes to Figure 9 ... 10 Updated Ordering Guide .. 5 Changes to Inverting Closed-Loop Frequency Response Updated Outline Dimensions .. 22 Section .. 20 Moved Leakage Currents Section, Input Capacitance Section,
and Output Capacitance Section ... 23
4/2003—Rev. B to Rev. C.
Moved Input-to-Input Coupling Section, Wideband Added SOIC-8 (R) for the AD8065 ... 4 Photodiode Preamp Section, and Figure 59 .. 24 Changes to Table 5 .. 25 Moved Figure 60 and High Speed JFET Input Instrumentation
2/2003—Rev. A to Rev. B.
Amplifier Section .. 25 Changes to Absolute Maximum Ratings... 4 Updated Outline Dimensions .. 27 Changes to Test Circuit 10 ... 14 Changes to Ordering Guide ... 28 Changes to Test Circuit 11 ... 15 Added Automotive Products Section ... 28 Changes to Noninverting Closed-Loop Frequency Response 16 Changes to Inverting Closed-Loop Frequency Response ... 16 Updated Figure 6 .. 18
3/2009—Rev. H to Rev. I
Changes to Figure 7 .. 19 Changes to High Speed JFET Input Instrumentation Amplifier Changes to Figure 10 .. 21 Section .. 23 Changes to Figure 11 .. 22 Updated Outline Dimensions .. 24 Changes to High Speed JFET Instrumentation Amplifier .. 22 Changes to Video Buffer .. 22
9/2008—Rev. G to Rev. H
Deleted Usable Range Parameter, Table 1 .. 3 Deleted Usable Range Parameter, Table 2 .. 4
8/2002—Rev. 0 to Rev. A.
Deleted Usable Range Parameter, Table 3 .. 5 Added AD8066 .. Universal Changes to Layout ... 6 Added SOIC-8 (R) and MSOP-8 (RM) ... 1 Changes to Input and Output Overload Behavior Section .. 19 Edits to General Description .. 1 Changes to Table 5 Expressions Column ... 22 Edits to Specifications .. 2 New Figure 2 ... 5 Changes to Ordering Guide .. 5
1/2006—Rev. F to Rev. G
Edits to TPCs 18, 25, and 28 ... 8 Changes to Ordering Guide ... 26 New TPC 36 ... 11
12/2005—Rev. E to Rev. F
Added Test Circuits 10 and 11 .. 14 Updated Format .. Universal MSOP (RM-8) Added .. 23 Changes to Features .. 1 Rev. L | Page 3 of 28 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications ±5 V Specifications ±12 V Specifications +5 V Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Test Circuits SOIC-8 Pinout Theory of Operation Closed-Loop Frequency Response Noninverting Closed-Loop Frequency Response Inverting Closed-Loop Frequency Response Wideband Operation Input Protection Thermal Considerations Input and Output Overload Behavior Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Input-to-Output Coupling Wideband Photodiode Preamp High Speed JFET Input Instrumentation Amplifier Video Buffer Outline Dimensions Ordering Guide Automotive Products
