Datasheet AD8065, AD8066 (Analog Devices) - 4
DescriptionHigh Performance, 145 MHzFastFET Op Amp
Pages / Page28 / 4 — AD8065/AD8066. Data Sheet. SPECIFICATIONS ±5 V. Table 1. Parameter. …
RevisionL
File Format / SizePDF / 969 Kb
AD8065/AD8066. Data Sheet. SPECIFICATIONS ±5 V. Table 1. Parameter. Conditions. Min. Typ. Max Unit
AD8065/AD8066 Data Sheet SPECIFICATIONS ±5 V Table 1 Parameter Conditions Min Typ Max Unit
@ TA = 25°C, VS = ±5 V, RL = 1 kΩ, unless otherwise noted.
Table 1. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +1, VO = 0.2 V p-p (AD8065) 100 145 MHz AD8065WARTZ only: TMIN − TMAX 88 MHz G = +1, VO = 0.2 V p-p (AD8066) 100 120 MHz G = +2, VO = 0.2 V p-p 50 MHz G = +2, VO = 2 V p-p 42 MHz Bandwidth for 0.1 dB Flatness G = +2, VO = 0.2 V p-p 7 MHz Input Overdrive Recovery Time G = +1, −5.5 V to +5.5 V 175 ns Output Recovery Time G = −1, −5.5 V to +5.5 V 170 ns Slew Rate G = +2, VO = 4 V step 130 180 V/µs AD8065WARTZ only: TMIN − TMAX 155 V/µs Settling Time to 0.1% G = +2, VO = 2 V step 55 ns G = +2, VO = 8 V step 205 ns NOISE/HARMONIC PERFORMANCE SFDR fC = 1 MHz, G = +2, VO = 2 V p-p −88 dBc fC = 5 MHz, G = +2, VO = 2 V p-p −67 dBc fC = 1 MHz, G = +2, VO = 8 V p-p −73 dBc Third-Order Intercept fC = 10 MHz, RL = 100 Ω 24 dBm Input Voltage Noise f = 10 kHz 7 nV/√Hz Input Current Noise f = 10 kHz 0.6 fA/√Hz Differential Gain Error NTSC, G = +2, RL = 150 Ω 0.02 % Differential Phase Error NTSC, G = +2, RL = 150 Ω 0.02 Degrees DC PERFORMANCE Input Offset Voltage VCM = 0 V, SOIC package 0.4 1.5 mV AD8065WARTZ only: TMIN − TMAX 2.6 mV Input Offset Voltage Drift 1 17 µV/°C AD8065WARTZ only: TMIN − TMAX 17 µV/°C Input Bias Current SOIC package 2 6 pA TMIN to TMAX 25 125 pA Input Offset Current 1 10 pA TMIN to TMAX 1 125 pA Open-Loop Gain VO = ±3 V, RL = 1 kΩ 100 113 dB AD8065WARTZ only: TMIN − TMAX 100 dB INPUT CHARACTERISTICS Common-Mode Input Impedance 1000 || 2.1 GΩ || pF Differential Input Impedance 1000 || 4.5 GΩ || pF Input Common-Mode Voltage Range FET Input Range −5 to +1.7 −5.0 to +2.4 V AD8065WARTZ only: TMIN − TMAX −5 to +1.7 V Common-Mode Rejection Ratio VCM = −1 V to +1 V −85 −100 dB VCM = −1 V to +1 V (SOT-23) −82 −91 dB AD8065WARTZ only: TMIN − TMAX −82 dB Rev. L | Page 4 of 28 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications ±5 V Specifications ±12 V Specifications +5 V Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Test Circuits SOIC-8 Pinout Theory of Operation Closed-Loop Frequency Response Noninverting Closed-Loop Frequency Response Inverting Closed-Loop Frequency Response Wideband Operation Input Protection Thermal Considerations Input and Output Overload Behavior Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Input-to-Output Coupling Wideband Photodiode Preamp High Speed JFET Input Instrumentation Amplifier Video Buffer Outline Dimensions Ordering Guide Automotive Products
