Sequential Turn Lights Driver
Four-LED left and right sequence
Particularly suited to motorcycles
Circuit diagram:
Parts:
R1
500K 1/2W Trimmer Cermet or Carbon
R2
47K 1/4W Resistor
R3,R4
1K 1/4W Resistors
R5,R6,R7,R8
10K 1/4W Resistors
C1
1µF 63V Polyester or electrolytic capacitor
C2
220µF 25V Electrolytic capacitor
D1-D8
LEDs Yellow ultra-bright types
Q1,Q2,Q3,Q4
BC337   45V 800mA NPN Transistors
IC1
7555 or TS555CN or TLC555CP CMos Timer IC
IC2
4017 Decade counter with 10 decoded outputs IC
SW1
Vehicle Turn Lights switch (See Comments)
Battery
12V Vehicle battery
Comments:
This device was designed on request and allows sequential operation of four Leds either to left or right direction, obtained by means of a 7555 CMos timer IC (IC1) wired as an astable multivibrator driving a Decade counter (IC2). This IC is set to count a sequence of four by connection of pin #10 to pin #15, but any sequence count in the 2-10 range can be set by choosing the appropriate pin connection. Obviously, LEDs, Transistors and their respective Base-limiting resistors must also be added or omitted accordingly.
R1 is a variable resistor (Trimmer), used to set the desired speed of the LEDs. SW1 is a change-over switch that should already exist in your motorcycle, having a center-off position and Turn-left and Turn-right positions.
D1, D3, D5 and D7 are the Turn-left LEDs; D2, D4, D6 and D8 are the Turn-right LEDs.
For a motorcycle they are arranged on a single board about 20 - 25 cm wide as shown in the image below. The outer red LEDs are the tail/brake lights and can be driven by a circuit like the LED driven tail/brake Light Cluster available on this website.
Note:
  • The use of high brightness, high efficiency yellow LED types of suitable size is mandatory.
redcircuits.com
