Circuit forms adjustable bipolar clamp
Texas Instruments TL082
The easy way to clamp a signal to a given value is to use two zener diodes, connected back-to-back. This method has several disadvantages. The accuracy of the clamping depends on the tolerance of the zener diodes, and the clamping is not adjustable, except by changing diodes.
This circuit provides adjustable clamping over the range of ±1 to ±10 V.
Figure 1. This circuit provides adjustable clamping over the range of ±1 to ±10 V.
The circuit in Figure 1 is a bipolar clamper with a range of ±1 to ±10 V, with the clamping level a function of the input VCLAMP. IC1A, IC1B, and IC3A are unity-gain buffers. IC2A is a positive clamper, and IC2B is a negative clamper. Figure 2 shows the transfer function, with VCLAMP set at –5 V. You can change VCLAMP over the range of –1 to –10 V and thereby change the clamping level. If VIN is within –VCLAMP to + VCLAMP, then VOUT = VIN. If VIN exceeds VCLAMP, then VOUT = VCLAMP.
With VCLAMP set at -5 V, the output clamps firmly at ±5 V.
Figure 2. With VCLAMP set at –5 V, the output clamps firmly at ±5 V.
To explain how the circuit works, assume four cases, with four values of VIN. Basically, the circuit works in two modes: the linear mode, in which diodes D1 and D2 are open switches, and the clamped mode, in which the diodes are closed switches. Table 1 gives results for the four cases. In Case A, the input is 7 V, VCLAMP is –5 V, D1 conducts, and D2 is an open switch. The feedback loop around IC2A regulates the anode of D1 to 5 V and the output of IC2A to 4.4 V. In cases B and C, both diodes are open switches. In Case D, D2 conducts, and D1 is an open switch.
Table 1. Results for clamped and linear modes
Case VIN (V) VOUT (V) Mode
A 7 5 Clamped
B 3 3 Linear
C –3 –3 Linear
D –7 –5 Clamped
Materials on the topic
  1. Datasheet Texas Instruments TL082
EDN
