Datasheet HMC247 (Analog Devices) - 4
Description400° Analog Phase Shifter Chip, 5 - 18 GHz
Pages / Page6 / 4 — HMC247. 400° ANALOG PHASE SHIFTER. 5 - 18 GHz. Phase Shift vs. Pin @ 12 …
File Format / SizePDF / 332 Kb
HMC247. 400° ANALOG PHASE SHIFTER. 5 - 18 GHz. Phase Shift vs. Pin @ 12 GHz. Phase Shift vs. Pin @ 18 GHz
HMC247 400° ANALOG PHASE SHIFTER 5 - 18 GHz Phase Shift vs Pin @ 12 GHz Phase Shift vs Pin @ 18 GHz
HMC247
v03.0809
400° ANALOG PHASE SHIFTER 5 - 18 GHz Phase Shift vs. Pin @ 12 GHz Phase Shift vs. Pin @ 18 GHz
0.5 0.5 0V 0V 0.3 5V 0.3 5V 10V 10V 0.1 0.1 3 -0.1 -0.1 IP -0.3 -0.3 H NORMALIZED PHASE SHIFT (degrees) NORMALIZED PHASE SHIFT (degrees) -0.5 -0.5 -10 -5 0 5 -10 -5 0 5 INPUT POWER (dBm) INPUT POWER (dBm) OG - C L
Absolute Maximum Ratings
A N Control Voltage (Vctl) +11 Vdc Reverse Current 5 mA Input Power (RFin) +30 dBm S - A Channel Temperature (Tc) 150 °C R Continuous Pdiss (T = 85 °C) 1.83 W E (derate 28 mW/°C above 85 °C) T Thermal Resistance 35.6 °C/W (junction to die bottom) IF Storage Temperature -65 to +150 °C H Operating Temperature -55 to +85 °C E S S A H P Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
3 - 5
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
