Datasheet HMC365G8 (Analog Devices) - 2
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz
Pages / Page6 / 2 — HMC365G8. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 13 GHz. Input Sensitivity …
File Format / SizePDF / 353 Kb
HMC365G8. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 13 GHz. Input Sensitivity Window, T= 25 °C
HMC365G8 SMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz Input Sensitivity Window, T= 25 °C
HMC365G8
v02.0410
SMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz Input Sensitivity Window, T= 25 °C Input Sensitivity Window vs. Temperature
20 20 4 10 10 Min Pin + 25C
Recommended
0 0 Max Pin + 25C Min Pin + 85C T
Operating Window
Max Pin + 85C Min Pin -40C Max Pin -40C -10 -10 INPUT POWER (dBm) INPUT POWER (dBm) -20 -20 S - SM -30 -30 R 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 O INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) T C E
SSB Phase Noise
T
Output Power vs. Temperature Performance, Pin= 0 dBm, T= 25 °C
E 10 0 -20 8 & D -40 S -60 6 R -80 E + 25C 4 + 85C -100 - 40C ID OUTPUT POWER (dBm) -120 2 IV SSB PHASE NOISE (dBc/Hz) -140 0 -160 Y D 0 3 6 9 12 15 102 103 104 105 106 107 INPUT FREQUENCY (GHz) OFFSET FREQUENCY (Hz) NC E
Output Harmonic
U
Content, Pin= 0 dBm, T= 25 °C Reverse Leakage, Pin= 0 dBm, T= 25 °C
Q 0 0 E R -10 Both Output Ports Terminated -10 F One Output Port Terminated -20 -20 -30 -30 -40 OUTPUT LEVEL (dBm) Pfeedthru POWER LEVEL (dBm) -40 2nd Harmonic 3rd Harmonic -50 -50 -60 0 3 6 9 12 15 0 3 6 9 12 15 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4 - 2
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
