Datasheet HMC365G8 (Analog Devices) - 3
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz
Pages / Page6 / 3 — HMC365G8. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 13 GHz. Output Voltage …
File Format / SizePDF / 353 Kb
HMC365G8. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 13 GHz. Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC365G8 SMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC365G8
v02.0410
SMT GaAs HBT MMIC DIVIDE-BY-4, DC - 13 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C Absolute Maximum Ratings
4 700 RF Input (Vcc = +5V) +13 dBm Vcc +5.5V 500 Junction Temperature (T ) 135 °C j 300 T Continuous Pdiss (T = 85 °C) 625 mW 100 (derate 12.5 mW/° C above 85 °C) Thermal Resistance (R ) TH -100 80 °C/W (junction to ground paddle) AMPLITUDE (mV) -300 Storage Temperature -65 to -150 °C S - SM Operating Temperature -40 to +85 °C -500 R O -700 22.7 23.1 23.5 23.9 24.3 24.7 T TIME (nS) C
Typical Supply Current vs. Vcc
E T Vcc (V) Icc (mA) ELECTROSTATIC SENSITIVE DEVICE E 4.75 110 OBSERVE HANDLING PRECAUTIONS 5.0 120 5.25 130 & D Note: Divider will operate over full voltage range shown above S R E
Outline Drawing
ID IV Y D NC E U Q E R F NOTES: 1. PACKAGE MATERIAL: ALUMINA LOADED BOROSILICATE GLASS. 2. LEAD, BASE, COVER MATERIAL: KOVAR™ (#7052 CORNING). 3. PLATING: ELECTROLYTIC GOLD 50 MICROINCHES MIN., OVER ELECTROLYTIC NICKEL 50 MICROINCHES MIN. 4. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 5. TOLERANCES: ±.005 [0.13] UNLESS OTHERWISE SPECIFIED. 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
4 - 3
Phone: 978-250-3343 Fax: 978-250-3373 O P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
