Datasheet HMC6187LP4E (Analog Devices) - 6
DescriptionVariable Gain Amplifier SMT, 27 - 31.5 GHz
Pages / Page8 / 6 — HMC6187LP4E. VARIABLE GAIN AMPLIFIER. 27 - 31.5 GHz. Pin Descriptions
HMC6187LP4E VARIABLE GAIN AMPLIFIER 27 - 31.5 GHz Pin Descriptions
HMC6187LP4E
v00.0312
pin number function Description interface Schematic 1, 2, 4, 5, 6, 7, T These pins and exposed ground paddle must be connected to 12, 13, 14, 15, 17, GnD rf/DC ground. 18, 19, 24 m r - S 3 rfin This pin is aC coupled and matched to 50 Ohms. ie lif p adjust voltage to achieve typical idd. please follow “mmiC m 8, 11 Vgg1, 2 amplifier biasing procedure” a application note. in a Gain control Voltage for the amplifier. See assembly 9 Vctrl diagram for required external components. le G b ia r The pins are not connected internally: however all data shown a 10 nC herein was measured with these pins connected to rf/DC V ground externally. This pad is aC coupled 16 rfOUT and matched to 50 Ohms. Drain bias Voltage for the amplifier. See assembly diagram for 20, 21, 22, 23 Vdd4, 3, 2, 1 required external components Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
