Datasheet HMC-ABH264 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 34 -42 GHz
Pages / Page6 / 3 — HMC-ABH264. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 34 - 42 GHz. Output …
File Format / SizePDF / 375 Kb
HMC-ABH264. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 34 - 42 GHz. Output IP3 vs. Temperature. Noise Figure vs. Temperature
HMC-ABH264 GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 34 - 42 GHz Output IP3 vs Temperature Noise Figure vs Temperature
HMC-ABH264
v01.0209
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 34 - 42 GHz Output IP3 vs. Temperature Noise Figure vs. Temperature
35 10 +25C 33 +85C 8 3 -55C ) 31 (dB ) E 6 R U (dBm 29 IG F IP3 E 4 IS ip 27 O N h +25C 2 25 +85C -55C 23 0 34 36 38 40 42 44 34 36 38 40 42 44 r - C FREQUENCY (GHz) FREQUENCY (GHz) e w
Gain & Power vs.
o
Supply Voltage @ 38 GHz, Idd= 120mA Reverse Isolation vs. Temperature
p 25 0 r & (dBm) 20 -10 A Psat +25C e 15 (dB) -20 +85C -55C ION (dBm), 1dB 10 Gain(dB) -30 lin P1dB(dBm) ), P Psat(dBm) ISOLAT (dB 5 -40 IN s - A G r 0 -50 4.5 5 5.5 32 34 36 38 40 42 44 ie Vdd (V) FREQUENCY (GHz) lif p m
Power Compression @ 36 GHz Power Compression @ 40 GHz
A 24 24 ) 20 (% 20 (% E E A A ), P 16 ), P 16 (dB (dB IN 12 IN A 12 A ), G ), G m 8 m 8 Pout (dBm) out (dB Pout (dBm) 4 Gain (dB) out (dB P 4 Gain (dB) P PAE (%) PAE (%) 0 0 -18 -14 -10 -6 -2 2 6 10 14 -18 -14 -10 -6 -2 2 6 10 14 INPUT POWER (dBm) INPUT POWER (dBm) Infor F m o ati ro p n f ruirc n e ish ,e d d e b l y iv Anealroyg a D n evidc ets oi s pblealic ev e e d otr o d b e e ras cc: urH at it e taitne d M relia ic bler. ow Ho a we vve er , C n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
3 - 3
Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No O Ph rod n e e r : 7On 81- - 3 li 2 n 9-e 4 a 70t ww 0 • O w rd . e hi r ott nliite n .c e a o t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 pli co atri o ap n S p ups@ por h t it : Ptit hoen.c e o : 1 m -800-ANALOG-D
