Datasheet HMC-ABH264 (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 34 -42 GHz
Pages / Page6 / 4 — HMC-ABH264. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 34 - 42 GHz. …
File Format / SizePDF / 375 Kb
HMC-ABH264. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 34 - 42 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC-ABH264 GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 34 - 42 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC-ABH264
v01.0209
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 34 - 42 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd1, Vdd2, Vdd3) 5.5 V Vdd (V) idd (mA) Gate Bias Voltage (Vgg) -1 to 0.3 Vdc 4.0 114 rf input power (rfin)(Vdd = +5Vdc) +10 dBm 4.5 117 Channel Temperature 180 °C 5.0 120 Note: Amplifier will operate over full voltage ranges shown above. 3 Continuous pdiss (T= 85 °C) 1 w Vgg adjusted to achieve Idd= 120mA at +5V. (derate 10.8 mw/°C above 85 °C) Thermal resistance 93 °C/w (channel to die bottom) ip storage Temperature -65 to +150 °C eleCTrosTATiC sensiTiVe DeViCe h operating Temperature -55 to +85 °C oBserVe hAnDlinG preCAUTions
Outline Drawing
r - C e w o p r & A e lin s - r ie lif p m A
Die Packaging Information
[1] noTes: 1. All Dimensions Are in inChes [mm] standard Alternate 2. Die ThiCKness is .004” Gp-2 (Gel pack) [2] 3. TYpiCAl BonD is .004” sQUAre 4. BACKsiDe meTAlliZATion: GolD [1] Refer to the “Packaging Information” section for die 5. BonD pAD meTAlliZATion: GolD packaging dimensions. 6. BACKsiDe meTAl is GroUnD. [2] For alternate packaging information contact Hittite 7. ConneCTion noT reQUireD for UnlABeleD BonD pADs. Microwave Corporation. Info F rmoatri op n rfiurcne is ,h ed d ebly ivAe n r al y o g aDn evdic eto s i p s bla eli c evee d otro dbe e ras: cc uH ratite tiatne d M reli iac bl reo . w Ho av wev e er , Cno o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No O P r h d o e ne r O : 7 n 81- -3li 2n 9 e - 4 a 7 t 0 ww 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
3 - 4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p li coarti o ap n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
