Datasheet ADPA7007CHIP (Analog Devices)
Description | GaAs, pHEMT, MMIC,1 W Power Amplifier, 18 GHz to 44 GHz |
Pages / Page | 25 / 1 — GaAs, pHEMT, MMIC,1 W Power Amplifier,. 18 GHz to 44 GHz. Data Sheet. … |
File Format / Size | PDF / 531 Kb |
GaAs, pHEMT, MMIC,1 W Power Amplifier,. 18 GHz to 44 GHz. Data Sheet. ADPA7007CHIP. FEATURES. FUNCTIONAL BLOCK DIAGRAM
GaAs, pHEMT, MMIC,1 W Power Amplifier, 18 GHz to 44 GHz Data Sheet ADPA7007CHIP FEATURES FUNCTIONAL BLOCK DIAGRAM Output P1dB: 31 dBm typical at 22 GHz to 36 GHz P VGG1 VDD1 VDD3 VREF SAT: 32 dBm typical at 22 GHz to 36 GHz Gain: 21.5 dB typical at 22 GHz to 36 GHz Output IP3: 41 dBm typical at 22 GHz to 44 GHz Supply voltage: 5 V typical at 1400 mA maximum ADPA7007CHIP 50 Ω matched input and output RFIN Die size: 3.610 mm × 3.610 mm × 0.102 mm RFOUT APPLICATIONS Military and space VDET Test instrumentation
001
VGG2 VDD2 VDD4
21924- Figure 1.
GENERAL DESCRIPTION
The ADPA7007CHIP is a gallium arsenide (GaAs), order intercept (IP3) of 41 dBm. The ADPA7007CHIP requires pseudomorphic high electron mobility transistor (pHEMT), 1400 mA from a 5 V supply on the supply voltage (VDD) and monolithic microwave integrated circuit (MMIC), distributed features inputs and outputs that are internal y matched to 50 Ω, power amplifier that operates from 18 GHz to 44 GHz. The facilitating integration into multichip modules (MCMs). All amplifier provides a gain of 21.5 dB, an output power for 1 dB data was taken with the chip connected via two 0.025 mm wire compression (P1dB) of 31 dBm, and a typical output third- bonds that are at least 0.31 mm long.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2020 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 22 GHz FREQUENCY RANGE 22 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings ADPA7007CHIP ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT IDD OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS Handling Precautions Mounting Wire Bonding BIASING ADPA7007CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR ADPA7007CHIP VGGx ABSOLUTE MAXIMUM RATING REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
