ADPA7007CHIPData Sheet36 GHz TO 44 GHz FREQUENCY RANGE TA = 25°C, VDD = 5 V, and IDQ = 1400 mA for nominal operation, unless otherwise noted. Table 3. ParameterSymbol MinTypMaxUnitTest Conditions/Comments FREQUENCY RANGE 36 44 GHz GAIN 18 21 dB Gain Flatness ±0.7 dB Gain Variation Over Temperature 0.039 dB/°C NOISE FIGURE 6.5 dB RETURN LOSS Input 21 dB Output 18 dB OUTPUT Output Power for 1 dB Compression P1dB 27 30 dBm Saturated Output Power PSAT 31.5 dBm Output Third-Order Intercept IP3 41 dBm Measurement taken at POUT per tone = 16 dBm SUPPLY Quiescent Current IDQ 1400 mA Adjust (VGG1and VGG2) between −1.5 V up to 0 V to achieve the desired IDQ Voltage VDD 4 5 V Rev. 0 | Page 4 of 25 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 22 GHz FREQUENCY RANGE 22 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings ADPA7007CHIP ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT IDD OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS Handling Precautions Mounting Wire Bonding BIASING ADPA7007CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR ADPA7007CHIP VGGx ABSOLUTE MAXIMUM RATING REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
