Data SheetADPA7007CHIPSPECIFICATIONS 18 GHz TO 22 GHz FREQUENCY RANGE TA = 25°C, VDD = 5 V, and quiescent supply current (IDQ) = 1400 mA for nominal operation, unless otherwise noted. Table 1. ParameterSymbol Min TypMax UnitTest Conditions/Comments FREQUENCY RANGE 18 22 GHz GAIN 20 23 dB Gain Flatness ±0.1 dB Gain Variation Over Temperature 0.011 dB/°C NOISE FIGURE 6.5 dB RETURN LOSS Input 15.5 dB Output 26.5 dB OUTPUT Output Power for 1 dB Compression P1dB 26 28.5 dBm Saturated Output Power PSAT 30 dBm Output Third-Order Intercept IP3 37 dBm Measurement taken at output power (POUT) per tone = 16 dBm SUPPLY Quiescent Current IDQ 1400 mA Adjust the gate bias voltage (VGG1and VGG2) between −1.5 V up to 0 V to achieve the desired IDQ Voltage VDD 4 5 V 22 GHz TO 36 GHz FREQUENCY RANGE TA = 25°C, VDD = 5 V, and IDQ = 1400 mA for nominal operation, unless otherwise noted. Table 2. ParameterSymbolMin TypMax UnitTest Conditions/Comments FREQUENCY RANGE 22 36 GHz GAIN 19.5 21.5 dB Gain Flatness ±1.4 dB Gain Variation Over Temperature 0.026 dB/°C NOISE FIGURE 5.5 dB RETURN LOSS Input 17 dB Output 22 dB OUTPUT Output Power for 1 dB Compression P1dB 29 31 dBm Saturated Output Power PSAT 32 dBm Output Third-Order Intercept IP3 41 dBm Measurement taken at POUT per tone = 16 dBm SUPPLY Quiescent Current IDQ 1400 mA Adjust the (VGG1and VGG2) between −1.5 V up to 0 V to achieve the desired IDQ Voltage VDD 4 5 V Rev. 0 | Page 3 of 25 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 22 GHz FREQUENCY RANGE 22 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings ADPA7007CHIP ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT IDD OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS Handling Precautions Mounting Wire Bonding BIASING ADPA7007CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR ADPA7007CHIP VGGx ABSOLUTE MAXIMUM RATING REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
