Datasheet MAX9910, MAX9911, MAX9912, MAX9913 (Analog Devices) - 7
Description | 200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown |
Pages / Page | 17 / 7 — 200kHz, 4µA, Rail-to-Rail. I/O Op Amps with Shutdown. MAX9910–MAX9913. … |
File Format / Size | PDF / 515 Kb |
200kHz, 4µA, Rail-to-Rail. I/O Op Amps with Shutdown. MAX9910–MAX9913. Typical Operating Characteristics (continued)
200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown MAX9910–MAX9913 Typical Operating Characteristics (continued)
(VDD = 3V, VSS = VCM = 0V, RL to VDD / 2, TA = +25°C, unless otherwise noted.)
VOLTAGE-NOISE DENSITY RESISTOR ISOLATION vs. FREQUENCY vs. CAPACITIVE LOAD POWER-UP SETTLING TIME
MAX9910 toc21 10,000 8000 AV = 1V/V 7000 FOR AV = 10V/V MAX9910 toc19 NO R MAX9910 toc20 ISO NEEDED V 6000 DD √Hz) 1V/div ) 5000 Ω ( 1000 4000 R ISO 3000 VOLTAGE NOISE (nV/ OUTPUT 2000 500mV/div 1000 IN+ = VDD / 2 AV = 1V/V 100 0 1 10 100 1k 10k 100k 10 100 1000 10,000 500ns/div FREQUENCY (Hz) CLOAD (pF)
SMALL-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE SHUTDOWN RESPONSE (CLOAD = 15pF) (CLOAD = 100pF)
MAX9910 toc22 MAX9910 toc23 MAX9910 toc24 IN+ = VDD / 2 AV = 1V/V AV = 10V/V AV = 1V/V 3V IN+ IN+ SHDN 50mV/div 5mV/div 0V 1.5V OUTPUT OUTPUT OUTPUT 50mV/div 50mV/div 0V 20µs/div 10µs/div 20µs/div
LARGE-SIGNAL PULSE RESPONSE LARGE-SIGNAL PULSE RESPONSE (CLOAD = 15pF) (CLOAD = 100pF)
MAX9910 toc25 MAX9910 toc26 AV = 1V/V AV = 10V/V IN+ IN+ 1V/div 100mV/div OUTPUT OUTPUT 1V/div 1V/div 10µs/div 100µs/div
_______________________________________________________________________________________ 7
