Flex Multi-Channel Low-Side Switches - the Perfect Fit for Powertrain, Safety and Industrial Applications
Infineon TLE 8718SA
Infineon's family of Flex multi-channel low-side switches is designed for powertrain, safety and industrial applications. They can be used to drive a range of loads from relays, injector valves and oxygen probe heaters through general purpose solenoids to unipolar stepper motors.
Infineon Flex
The all-round family concept offers full scalability from 2 to 18 channels and features leading-edge technology. All Flex multi-channel switches are equipped with embedded protection functions and enhanced diagnostics, making them the perfect fit for a wide range of industrial platforms.
Overview of Flex family applications
Infineon Flex
Features
  • Active clamping for inductive loads
  • Undervoltage protection
  • Overvoltage protection
  • Overcurrent protection
  • Overtemperature shutdown
  • Electrostatic discharge (ESD) protection
  • Direct input control (for PWM)
  • Communication interface (control/diagnosis)
  • Serial peripheral interface (SPI)
  • Microsecond channel (MSC)
  • 5 V and 3.3 V µC compatibility
  • Status flag
  • 2-bit diagnosis feedback for:
  • Short-to-GND
  • Open load
  • Overcurrent / overtemperature
  • Normal operation
Applications
  • Product family concept that can be adapted to various system and partitioning requirements
  • Dedicated feature set for engine management applications
  • Designed for dedicated applications, but also available as standard products for off-the-shelf use
  • Overvoltage protection on all pins (TLE 8718SA) supports safety-critical applications
  • Application boards available to start designs quickly
infineon-designlink.com
