If the load resistance is below a minimum value, the drive circuit allows only a small spike of current on each "on" transition
AuthorsJames Henden
Main DocumentArticle «Drive a resistive heater element without adding noise to the system»
DescriptionFigure 2
File Format / SizePDF / 19 Kb
If the load resistance is below a minimum value, the drive circuit allows only a small spike of current on each on transition
