Level translation in one direction requires half of the open-drain translation circuit (a). For a low-to-high transition, RC effects do not appear until the output rises to about 0.5 V below the lower supply voltage (b). The circuit also works for transla
AuthorsCC Poon, Edward Chui
Main DocumentArticle «Low-voltage interface circuits translate 1.8 to 5V»
DescriptionFigure 2
File Format / SizePDF / 17 Kb
Level translation in one direction requires half of the open-drain translation circuit (a) For a low-to-high transition, RC effects do not appear until the output rises to about 0.5 V below the lower supply voltage (b) The circuit also works for transla
