The test setup allows you to operate a MOSFET power switch at a fixed turn-on time. The power circuit remains cool with a 10-kHz repetition rate, even at peak inductor currents of tens of amperes
AuthorsMarián Štofka
Main DocumentArticle «Protect MOSFETs in heavy-duty inductive switched-mode circuits»
DescriptionFigure 1
File Format / SizePDF / 32 Kb
The test setup allows you to operate a MOSFET power switch at a fixed turn-on time The power circuit remains cool with a 10-kHz repetition rate, even at peak inductor currents of tens of amperes
