The linear/buck current sink extends the compliance range for current regulation down to a lower supply voltage (below 8 V), compared with the buck regulator alone, and reduces EMI with low battery. As a result, the LEDs can remain on under low-battery co
Figure 2. The linear/buck current sink extends the compliance range for current regulation down to a lower supply voltage (below 8 V), compared with the buck regulator alone, and reduces EMI with low battery. As a result, the LEDs can remain on under low-battery co
