Auto-Audio
Bad Prescript
Music
Simple local low-noise voltage …
Simple local low-noise voltage converter that can be used when a simple negative supply of low voltage is required
Peter Demchenko
Using an inductor to improve an existing design
Figure 1
11 Kb
Figure 1. Simple local low-noise voltage converter that can be used when a simple negative supply of low voltage is required
Figure 2. Added inductance to the output of Figure 1 to improve converter efficiency
Figure 3. Circuit that ensures any drop is voltage is detected that may result in distorted results for converters in Figure 1 and Figure 2
