Auto-Audio
Bad Prescript
Music
This solar lighting system …
This solar lighting system uses the PV-pushback-effect to get constant light output
Vijay Deshpande
Solar constant lighting system uses PV-pushback-effect. Part 1 - System description
Figure 1
8 Kb
Figure 1. This solar lighting system uses the PV-pushback-effect to get constant light output
Figure 2. The chart shows the characterization of the PV array under constant sunlight intensity
Figure 3. The proposed solar lighting system circuit diagram supports the PV-pushback-effect
Figure 4. The plot shows the PV array power versus V
PV
voltage for the SDL with the converter OFF
