Circuits & Schematics
Search results: 2,182 Output: 1-10
  1. Jim Williams
    Circuits Analogue Design Measurement Analog Devices LT1006 LT1009 LT1027 LT1078 LTC1290
    High accuracy, stability, and wide operating range make platinum RTDs (resistance temperature detectors) popular temperature transducers. Signal conditioning these devices requires care to utilize their desirable characteristics. Figure 1’s ...
    Sep 10, 2025
  2. T.K. Hareendran
    In today’s world, both households and industrial facilities are exploring ways to improve power reliability by harnessing multiple energy sources, not just the electricity from the grid. One clever solution: Automatic transfer switch (ATS). ...
    Sep 8, 2025
  1. Stephen Woodward
    Accurate, inexpensive, and mature platinum resistance temperature detectors (PRTDs) with an operating range extending from the cryogenic to the incendiary are a gold (no! platinum! ) standard for temperature measurement. Similarly, the 4 to 20 mA ...
    Sep 2, 2025
  2. T A Babu
    Boost converters are non-isolated DC-DC converters that step up voltage. In some applications, users expect protection against reverse polarity, short circuits, and other anomalous conditions. The basic PWM boost topology is shown in Figure 1. ...
    Sep 2, 2025
  3. David A. Johnson
    Conventional astable oscillator circuits that use CMOS logic gates, bipolar transistors or low current op Amps, often require more current than necessary. The circuit shown generates a low frequency square wave signal while drawing only 0.5 ...
    Aug 31, 2025
  4. Stephen Woodward
    Design Idea (DI) contributors have recently explored various possibilities for ON/OFF power control using just a momentary contact “shiny modern push-button,” many of which build off of Nick Cornford’s “To press on or hold ...
    Aug 26, 2025
  5. Mitchell Lee
    Isolated flyback converters usually evoke thoughts-or bitter memories-of custom transformers, slipped delivery schedules, and agency-approval problems. Off-the-shelf flyback transformers carry isolation ratings of only 300 to 500 V and rarely of as ...
    Aug 26, 2025
  6. Lukasz Sliwczynski Przemyslaw Krehlik
    To generate high voltages with proper insulation between the “hot node” and the rest of the circuitry, a car ignition coil can function in place of a high-voltage transformer. These coils have voltage ratings of approximately 20 kV, so ...
    Aug 26, 2025
  7. Christopher Jarboe Thomas Mosteller
    Professional condenser microphones require a 48-V supply to charge the internal capacitive transducer and power the internal buffer for the high-impedance transducer output. You can use a simple boost converter, a filter circuit to reduce ...
    Aug 25, 2025
  8. Nick Cornford
    We recently saw how certain audio power amplifiers can be used as oscillators ( Ref. 1 ). This Design Idea shows how those same parts can be used for simple amplitude modulation, which is trickier than it might seem. The relevant device is the ...
    Aug 20, 2025
