Auto-Audio
Bad Prescript
Music
The performance of the …
The performance of the circuit: Top: two complementary outputs, Middle: input voltage with large common mode, Bottom: the differential output
Chau Tran, Jordyn Rombola
Simple discrete SE-to-differential precision in-amp circuit: High common-mode input range and 50% less power
Figure 2
8 Kb
Figure 1. The single-ended input differential output amplifier
Figure 2. The performance of the circuit: Top: two complementary outputs, Middle: input voltage with large common mode, Bottom: the differential output
