Add 512K of external SRAM to Arduino Mega. Part 2 - Schematic and PCB
Arduino Arduino Mega
Pin mappings
Here’s how the Arduino maps the xmem pins. As you can see they’re all conveniently placed in a block at the end of the board. That will make it easy for me to design a PCB that just plugs straight in. Thanks go out from me to the Arduino designers for thinking of this.
AVR
SRAM
The pins overlaid in red are used by the xmem interface, those in green will be used by me to control the active memory bank.
22
AD0/PA0
D0
23
AD1/PA1
D1
24
AD2/PA2
D2
25
AD3/PA3
D3
26
AD4/PA4
D4
27
AD5/PA5
D5
28
AD6/PA6
D6
29
AD7/PA7
D7
30
A15/PC7
A15
31
A15/PC6
A14
32
A15/PC5
A13
33
A15/PC4
A12
34
A15/PC3
A11
35
A15/PC2
A10
36
A15/PC1
A9
37
A15/PC0
A8
38
PD7/T0
BANK0
39
ALE
latch enable
40
/RD/PG1
/RD
41
/WR/PG0
/WR
42
PL7
BANK1
43
PL6
BANK2
Here’s the full schematic that I created using the free version of the Eagle PCB CAD design program.
Принципиальная схема подключения внешней памяти SRAM к микроконтроллеру AVR
Click to enlarge
The schematic reflects the block diagram in the datasheet with the addition of 100nF capacitors around the power pins of the ICs and one 1µF across the board supply.
I have also added a LED each to the active-low /WR and /RD control lines so that reads and writes to the SRAM will be visible if enough happen in succession – a single read/write is so fast that the LED will not flash for long enough to be visible. These LEDs can be enabled with a jumper or disabled if I feel that I can’t afford the 7mA of current that they consume while active.
Part list
Part
Number
Package
Quantity
SRAM
Alliance AS7C4096A 12ns
44 pin TSOP-II
1
Latch
NXP 74AHC373
20 pin TSSOP-20
1
Capacitor
100nF
0603
3
Capacitor
1µF
0603
1
Resistor
approx 430Ω
0805
2
LED – yellow
Kingbright
1206
1
LED – red
Kingbright
1206
1
Jumper
2 pins
2.54mm
2
Male DIP header
22 pins
2.54mm
1
Male DIP header
6 pins
2.54mm
1
The PCB
I use the prototype PCB manufacturing service offered by ITead Studio. If your board is double sided and comes in at under 50mm square then they will charge US$9.95 for 10 copies including delivery.
Mine comes in at around 40×43mm so no problems there. ITead supply a DRC file that you can use to validate your design against their equipment. The finest trace/space they can handle is 6mil but in my opinion you’d be asking for manufacturing faults at that level so I try to stick to 10mil or higher.
Вид готовой печатной платы
The bare PCB
Soldering SMD parts
If you google around the internet you’ll find a few articles dedicated to explaining how you can hand-solder SMD parts. The method that I use is to pre-tin all the solder pads with a normal iron and then fix the parts by reflowing the solder with a hot air gun. I use regular solder (not paste) and smelly, messy but very effective rosin flux when working with the regular iron and no-clean liquid flux when working with the hot air gun.
The secret to success here is to use an absolutely tiny amount of solder on each pad when tinning so the pad goes from flat to a tiny bump. If you create too much of a solder bump then multi-pin parts will not sit down evenly and you’ll have to manually fix them up afterwards with a fine-tip iron and a microscope.
Although the hot air station makes working with SMD parts quite simple I think in future I’ll set a minimum size of 0805 for the discrete parts because 0603 is just too fiddly to work with.
After soldering I inspect each joint with a 20x binocular (stereo) microscope and resolve any dry joints with the finest tip soldering iron that I have.
Плата с установленными компонентами
The finished PCB
The finished PCB is designed to press directly into the Arduino Mega connectors without blocking off any more pins than it uses. Finally here’s a picture of the daughterboard attached to the Arduino Mega 1280. The GND and 5V supply pins are not connected in this image.
Плата с внешней памятью, подключенная к плате Фквгштщ
Attached to the Arduino
andybrown.me.uk
