Introduction
Pulse Generator kit will generate a frequency in KHz which can form a good test gear project. This kit is based on the classic LM555 timer IC.
Input - 12 VDC Max @ 40 mA
- Range - jumper selectable and preset tunable range of 1 Hz to 180 KHz
- Power-On LED indicator
- Terminal pins for easy connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 40 mm x 47 mm
Schematic
Schematic
Layout
