Circuits & Schematics
Search results: 2,342 Output: 1-10
  1. David A. Johnson
    This timer circuit draws only 3 µA of current, and can be powered by DC supplies ranging from 3 V to 15 V. The circuit produces accurate pulses whose time can easily be adjusted, based on the R1 × C1 time constant. The time should not ...
    Oct 13, 2026
  2. Stephen Woodward
    This Design Idea enables you to program digital potentiometers with inexpensive rotary incremental encoders. Recent Design Ideas for circuits that manually control digital potentiometers have mostly “revolved” around UP/DOWN pushbutton ...
    Oct 8, 2026
  1. Stefan Wagner
    The USB PD adapter shown in Figure 1 is is a compact variable power supply capable of utilizing nearly any USB Type-C PD power supply with PPS-feature as an input to power your projects with various selectable voltages and high currents. Key ...
    Oct 8, 2026
  2. T.K. Hareendran
    Analog circuits have had their day; everything is digital now. However, here’s a simple analog circuit built with one good, old, but still available pulse-width-modulating regulator chip. The automatic DC heater controller circuit introduced ...
    Oct 6, 2026
  3. Stephen Woodward
    A curious connection of control buttons makes a simpler-is-better digital potentiometer interface possible. Two recent submissions to the Design Ideas kitchen (see Related Content) have shown different basic step-per-push pushbutton interfaces for ...
    Oct 5, 2026
  4. Stephen Woodward
    This versatile Design Idea survives and reports open- and short-circuits, not to mention multiplying efficiencies. Generally accepted tech folklore says that after you drive relays and solenoids into full actuation, only half as much coil voltage ...
    Sep 24, 2026
  5. Jayapal Ramalingam
    Using the concept and leveraging the example circuits in this Design Idea, you can divide any frequency by any number divisible by 2. Any dividend frequency can be divided by any number representable by 2 n , resulting in a square wave output ...
    Sep 23, 2026
  6. Mike (mixos)
    The circuit presented here is a 3 W stereo audio amplifier with memory UP/DOWN volume control. The project is based on PAM8408 IC from Diode Incorp which is a filter-less class-D amplifier with high SNR and Differential input which helps eliminate ...
    Sep 22, 2026
  7. David A. Johnson
    A single 1.5 V silver oxide button cell powers this complete touch activated switch circuit for 5 years. It features both a normally open and a normally closed set of solid state switch thermals. It also has an adjustable sensitivity, which can be ...
    Sep 22, 2026
  8. Stephen Woodward
    This circuit exemplifies the thesis that the 555 is to analog timing what the opamp is to analog “everything else”! In any contest to see which is easier to manually program, digital potentiometers (dpots) suffer a big handicap when ...
    Sep 21, 2026
