Auto-Audio
Bad Prescript
Music
Alternative adaptable pullup solution …
Alternative adaptable pullup solution that uses an analog switch to disconnect the "fast" part of the bus
Peter Demchenko
Adaptable pullup
Figure 2
11 Kb
Adaptable pullup
Figure 1. The adaptable pullup where a closed transistor connects additional resistors R5 and R6 in parallel to the main pullup resistors R1 and R2
Figure 2. Alternative adaptable pullup solution that uses an analog switch to disconnect the "fast" part of the bus
