JFETs typically require some reverse bias across the gate terminal and in HF/UHF applications, this is often provided using the voltage across resistor RS
Figure 1. JFETs typically require some reverse bias across the gate terminal and in HF/UHF applications, this is often provided using the voltage across resistor RS
