Izhar Fareed
Using this low cost Project one can reproduce AUDIO from TV without disturbing anyone. It does not use any wire between TV and headphone. In place of pair of wires it uses invisible Infrared light to transmit audio signals from TV to Headphone. Without using any lens a range of up to 6 meters is possible. Range can be extended by using Lenses and Reflectors with IR sensors comprising transmitters and receivers.
Figure 1. Audio transmitter
IR transmitter uses two-stage transistor amplifier to drive two IR leds connected in series. An audio output transformer is used (in reverse) to couple Audio output from TV to the IR transmitter. Transistors (BC547) & (BD140) amplify the audio signals received from TV through audio transformer low impedance output windings (lower gauge or thicker wire) are used for connection to TV side while high impedance are connected to the IR transmitter. This IR transmitter can be powered by 9v mains Adaptor or 9V Battery. Led in transmitter circuit functions as power-on indicator.
Figure 2. Audio reciever
IR receiver uses 3-stage transistors amplifier. The first two transistors (BC549C) from audio signal amplifier. While the third transistor (BD139) is used to drive a headphone. Adjust potmetre for max clarity. Direct photo transistor towards the IR Leds of transmitter for max range. A 9V Battery can be used to receiver circuit for portable operation.
